Firewall penetration
Fergus Kyle
PostPosted: Sat Jan 29, 2011 12:45 pm    Post subject: Firewall penetration Reply with quote
Fred,
You got the ‘annointed word’ from both experts so won’t add much, except to say i followed Bob Nuckolls’ suggestion on the topic and bought a 16 inch by 1-1/2 inch stainless steel towel rack, (I forget where, but a bathroom equipment supplier), which I then sawed off both ends to make two 90deg bends with attached flat mount plates. Through one of them I threaded fireproof tubing (with inside foreproof ‘wool’), and then threaded whatever through to the cockpit side. When the first one was full ( I didn’t need the second), I finished the connections and then stuffed the forward end with the usual red fireproof goop – see elsewhere for details.
This was well-treated as a topic on Bob’s Aeroelectric connection site. Sorry I’m nowhere near the sources for description, but hope you know the way.
good luck
Ferg
wiring wiring wiring [quote][b]
