Arplast PV-50
tim.rupp(at)remax.net
PostPosted: Mon Jan 31, 2011 1:41 pm    Post subject: Arplast PV-50 Reply with quote
Thanks Brian & Barry for you input.
I don’t have the earliest history on the prop as Dan had already flown the first ~60 hrs before I purchased his plane. From the time I started flying it, there really has been no grease leak at all. I’ve never opened up the hub itself, so the only “maintenance” that I’ve done is assuring the lead screw is greased and I’ve also replaced the batteries in the control unit.
As easy as it is to adjust the prop (thumb switch on the stick) the only reason I have considered the constant speed module is specifically so I don’t have to watch the tach like a hawk when I’m climbing out aggressively… A slight distraction and very subtle drop of the nose will let the rpm get away quickly! My display has not been calibrated to read actual degrees, but I use a spread of just over 9 degrees between take-off and cruise settings.
After my original post, I realized I mis-typed the name (Arplast) and that there are several blade combinations used so pitch info is going to be relative based on the blades used. As far as I know there isn’t a US distributor now, but if there is, let me know.
Tim Rupp
From: owner-pulsar-list-server(at)matronics.com [mailto:owner-pulsar-list-server(at)matronics.com] On Behalf Of Brian Anderson
Sent: Monday, January 31, 2011 1:03 PM
To: pulsar-list(at)matronics.com
Subject: Re: Pulsar-List: Aeroplast PV-50 issue
Hi Tim,
I've been using the PV50 for 10 years. Performance is great, and the only trouble I have had was a burned out pitch motor after about 200 hours. Arplast sold me a later version replacement which is working fine.
I've had grease escaping since day one. I used to put a lot of grease in the hub, but that is a waste of time because it just ends up on the canopy and especially around the front of the cowling inlets - - and on the front of the engine. More recently, at each annual, I dismantle the hub and re-grease the thrust bearings and put a smear on the swashplate and the sleeve bearings on each blade. I still get get grease thrown around for a few flights afterwards, but it gradually becomes less. There is still plenty of grease in the hub bearings each time I have opened it.
I have the 912 also. No CS unit, but I modified the control unit so that the pitch readout is in degrees of blade angle. I have a range from 18 to 30 degrees available. Did a lot of flight testing originally to determine optimum settings. Normally I use 21.5 degrees for take-off [but watch the rpm as you climb out], cruise at 5000 rpm and 25.6 degrees [or thereabouts] at 120 knots, and maximum speed at 5400 rpm is at about 28 degrees.
Like Barry, I occasionally use a fine pitch setting if I want to slow more quickly for landing - - as long as I know for sure that I am not going to go around. Actually, for a go-around the normal take-off setting of 21.5 is too fine, as you are already doing say 60 or 70 knots, so if that is likely to occur I need to be quick on resetting the pitch or take care adding power to avoid over-reving the engine. [And as you probably know, the Pulsar will climb out very well with less than full power.]
Since yours is probably a later prop, I wonder if the O-ring seals have been improved to lessen the grease escaping. Perhaps one blade seal is now less effective.
Brian
On 1/02/2011, at 5:43 AM, Tim Rupp wrote:
I haven’t investigated the source/cause yet, but all of the sudden (after ~200hrs) I had significant grease exiting around the root end of one of my three prop blades (Aeroplast PV-50 in-flight adjustable). It dotted my canopy a bit during the flight and after my flight there was a nice accumulation on the leading edge of my cowl. I’ll be checking it out later this week, but would appreciate any input, if by description someone else already knows what the issue is. While I’m on the topic, I’d also like to hear from anyone using the same prop (I don’t think there are many) regarding what range of pitch you are using on a 912S and whether any of you have used the constant speed controller.
Tim Rupp
 (512) 304-0029 mobile
style="color: blue; text-decoration: underline; ">http://www.matronics.com/Navigator?Pulsar-Listblue; text-decoration: underline; ">http://forums.matronics.comstyle="color: blue; text-decoration: underline; ">http://www.matronics.com/contribution
href="http://www.matronics.com/Navigator?Pulsar-List">http://www.matronhref="http://forums.matronics.com">http://forums.matronics.com
briana(at)xtra.co.nz
PostPosted: Mon Jan 31, 2011 2:10 pm    Post subject: Arplast PV-50 Reply with quote
Tim,
I have only dealt direct with the manufacturer in France, and there is no agent here in NZ either. The guy I have spoken with, Alain Petit, can speak a little English and I can understand a little French, so with a little difficulty we have sorted out any issues. He does respond in reasonable English to e-mails.
Making some small changes in the control unit to calibrate the display in degrees is not difficult. I'll send you a copy if you wish. I note that a later control unit, using an inverter instead of batteries is calibrated to read out in degrees. I find it helps to understand where the prop is.
Brian
On 1/02/2011, at 10:15 AM, Tim Rupp wrote:
[quote] st1\:*{behavior:url(#default#ieooui) } <![endif]--> <![endif]--> <![endif]-->
Tim Rupp
From: owner-pulsar-list-server(at)matronics.com (owner-pulsar-list-server(at)matronics.com) [mailto:owner-pulsar-list-server(at)matronics.com] On Behalf Of Brian Anderson
To: pulsar-list(at)matronics.com (pulsar-list(at)matronics.com)
Hi Tim,
Brian
Tim Rupp
href="http://www.matronics.com/Navigator?Pulsar-List">http://www.matronics.com/Navigator?Pulsar-List
