		william(at)gbta.net Guest
				 Posted: Mon Jan 31, 2011 11:43 am    Post subject: Tank attach zees |
				On page 18-4 step 1 we are instructed to rivet the  nutplates to the fuel tank attach zees (T-1012's).  Do we need to final  drill the bolt holes to a certain size or are they the correct size  already?
  My holes have paint in them from priming so at the  least, I need to run a bit through them to get the paint out.  Can someone  with unprimed Zee's tell me what size the hole is?
  Sorry if this should be common knowledge but I wanted to  make sure.
  Thanks in advance,
		Ron B.
				 Posted: Mon Jan 31, 2011 1:32 pm    Post subject: Re: Tank attach zees |
				If I had a memory I'd be dangerous. While building I have charts to check sizing. I do believe a K-1000-3 is for an AN 3 bolt. An an 3 bolt requires a #12 bit , going by memory. The Avery tool catalog had this information listed in it on page 57 a few years back. I think it is also in the red book from Van's.
 I can find out for sure if no one helps out, I'll have to go to the hangar.
 Ron
		larkrv10(at)yahoo.ca Guest
				 Posted: Mon Jan 31, 2011 7:26 pm    Post subject: Tank attach zees |
				Bill, as is said, timing is everything.  I just happened to prime my tank Zee's today.
  So there is a little epoxy primer in the holes, however it is not real hard yet.  Having said that, I was able to finger twirl a #13 drill bit but not a #12, as it seemed to catch some aluminum.
  So since a #13 is .185", I expect the holes are .002 or .003" shy of a #12 hole.  I'd drill them if it were me.
  Hope this helps.
  Rick
  #40956
  Southampton, Ont
 --- On Mon, 1/31/11, Billy & Tami Britton <william(at)gbta.net> wrote:
 Subject: Tank attach zees
 Received: Monday, January 31, 2011, 7:37 PM
  Thanks in advance,
 =nofollow target=_blank>http://www.matronics.com/Navigator?RV10-List
 et=_blank>http://forums.matronics.com
 llow target=_blank>http://www.matronics.com/contribution
