Richard Pike
				 Posted: Tue May 09, 2006 9:37 pm    Post subject: Redundancy.. I™m not gonna repeat myself ! |
				I have a 3 PSI Facet electric pump, mounted below the bottom of the tank
 which feeds straight into the Mikuni pulse pump. I turn it on to start
 and once the engine is running, turn it off for the taxi out and run up
 to make sure the Mikuni is working, then turn it back on prior to take
 off and leave it on. No reason to turn it off,  because leaving it on
 doesn't hurt a thing, but not leaving it on might just let the Mikuni
 die/582 die at precisely the wrong moment... After I land, I can turn it
 off again for the taxi back and see if the Mikuni is still alive, but at
 that point, who cares?
 I realize that some people turn the electric pump on for takeoff and
 then turn it back off, but to me that is like turning off one mag - Why?
 What are you saving it for? Just in case the other one breaks? So that
 you can then turn it on to calm your atrial fibrillation and hope for a
 restart?? A new Facet electric pump costs less than 40 bucks and it's
 mean time to failure is longer than any of us will live, so turn it on
 and leave it on!
 When I first flew to Oshkosh, I had a system like you describe in your
 post. I then met John Hauck, discussed my fuel system with him, and he
 was of the opinion that simpler is better. Made sense, so I eliminated
 all the extra plumbing and now run dual pumps all the time. One less
 thing to worry about. Oh yeah, ditch the squeeze bulb, the electric pump
 takes care of the prime.
 Richard Pike
 MKIII N420P (420ldPoops)
 Ralph Hoover wrote:
  Last Saturday, I was taking my shinny new DRE -2000 John Jung specials  (communication equipment) into the air for some landing time. They worked great and I discovered Ohio farm field hospitality up close and uncomfortable. I was taking off from my instructors field (1000 feet long) with my instructor aboard. As we climbed we lost a tad bit of air speed, not unnatural for 430 # of student and instructor and 60 degree temps. But then a surprise presented itself to us rather rudely. The engine went to idle! Looked to my left (the plane is a Challenger two place) and saw the throttle in its proper location, full open. As was appropriate, my instructor  took control. We were not more than 300 feet above ground level and the landing needed to be now.  There were several farm fields below us and he grabbed the closest one, unfortunately at a little bit of an angle with the plowed rows. Keeping trike front wheel up as long as possible, he brought it down as smoothly as could be do!
   ne. The field was rough but we were no worse for wear nor was the Challenger, thank God! This ride just gave me more interest to go flying not less, so I am ok with the landing. Now if I am ever faced with this choice or need, I will do it knowing what I will be getting into. Recently plowed corn fields are not fun. But I'm sure better than standing stalks!
  Now you probably want to know what this has to do with redundancy! Well here goes. The 503 DIDC and duel fuel supplied motor had a laps of NO or very low fuel. One cylinder didnt act funny, both were even. One carb would have allowed the engine to run at higher rpms but rough. Two fuel lines; one from the existing  mechanical fuel pump and one from an added electric fuel pump were plumbed into the system with appropriate check valves and  Ts . Apparently one check valve stuck and allowed fuel to backflow into the other fuel pump or there was an air leak between the hand pump choke (enricher from my old Harley days) . In an effort to be sure of fuel redundancy a new problem came about. I know that there are two schools that apply here and that both have been successful. School one says  keep it simple Stupid. The Rotax people know what their doing and if it were needed, they would have made a second fuel pump part of the package, even though a snowmobile stopping isnt the end!
    of someone's life. The other school applies the its better to be safe than sorry. After all, they have two carbs, two mags, two plugs, they would be better to have two fuel pumps.
  Anyone else experience this or anything like it? If so how did you correct the problem and does anyone have a specific suggestion to routing the fuel lines from both the mechanical pump and an electric fuel pump. I have read on this site where many use their electric fuel pump taking off and then shut it off for normal flight. I am about to re hose and add an electric fuel pump. I would very much appreciate any suggestions of success that you Kolbers have had.
  Sucking air here in Ohio Ralph
  http://forums.matronics.com/viewtopic.php?p=33718#33718
Kolb MKIII N420P (420ldPoops)
Kingsport, TN 3TN0
