Paul Valovich
Posted: Fri Feb 11, 2011 7:39 am Post subject: Icing Procedures |
We’ve beat the heated pitot theory to death� - how about a topic twist to discuss the step by step procedures one will employ before and after encountering actual icing?
My RV-8A has a Gertz heated pitot tube and an AFS 3500 Angle of Attack (I’m a former Navy carrier pilot so I’ve be weaned on AOA stuff).
Here’s my icing checklist – appreciate comments from those who think they have a better idea.
<![if !supportLists]>1.� <![endif]>If pilot decides potential icing
conditions exist, or prior to entering
clouds, or at very first sign of ice � PIOT HEAT ON
<![if !supportLists]>2.� <![endif]>AOA � � � � � � � CHECK/VERIFY OPERATION
<![if !supportLists]>3.� <![endif]>Indicated Airspeed/AOA � � � � MONITOR/CORRELATE
<![if !supportLists]>4.� <![endif]>At First Indication of Ice Accumulation� � CHANGE ALTITUDE AND/OR COURSE
<![if !supportLists]>5.� <![endif]>Monitor AOA and IAS
<![if !supportLists]>6.� <![endif]>If Icing Persists � � � LAND AS SOON AS PRACTICABLE
<![if !supportLists]>7. <![endif]>Enroute to Landing Site � CONTROLABILITY CHECK – (with sufficient altitude for stall/spin recovery)
(slow at 10mph intervals to 100 mph, then 5 mph intervals to approach to stall)
<![if !supportLists]>8. <![endif]>Landing Pattern � � � � 100 MPH OR AT LEAST +10 ABOVE APPROACH TO STALL
<![if !supportLists]>9. <![endif]>Established on Final � SLOW TO ENSURE SAFE LANDING ATTITUDE (my tailwheel’s on the front)
NOTES:
<![if !supportLists]>1. <![endif]>Ice accumulation is dynamic, not static. Always be prepared for handling surprises.
<![if !supportLists]>2. <![endif]>Closely monitor handling qualities in the landing pattern; do not get slow
<![if !supportLists]>3. <![endif]>If stall buffet occurs in pattern, abort and increase pattern speed on next approach
<![if !supportLists]>4. <![endif]>DO NOT STALL IN THE LANDING PATTERN
<![if !supportLists]>5. <![endif]>Get the plane safely on deck – do not worry about landing style points �
Posted: Fri Feb 11, 2011 8:04 am Post subject: Icing Procedures |
<snip>
Quote: | NOTES:
1. Ice accumulation is dynamic, not
2. Closely monitor handling qualities in
3. If stall buffet occurs in pattern,
4. DO NOT STALL IN THE LANDING PATTERN
5. Get the plane safely on deck � do not
Hear, hear . . .
All points offer due deference and diligence to the
probability that a once comfortable and friendly machine
may be suffering the effects of aerodynamic LSD.
I would add a reminder that pre-stall buffet may be minimal
to non-existent. The way the ice built on my personal
spirit-walk with the ice demons had the effect of adding
full length stall strip to the wing. It broke so quickly
that if there was any pre-stall buffet, it was not
noticeable.
longg(at)pjm.com Guest
In VFR weather a good pilot familiar with their craft should be able to
fly without an airspeed indicator. If you can't, you need more practice
to get the feel of your bird. Of course Navy pilots already know this.
Don't be so dependent on numbers.
Glenn E. Long
