Fuel Return Tee
pbesing(at)yahoo.com
PostPosted: Tue May 09, 2006 7:33 pm    Post subject: Fuel Return Tee Reply with quote
I'm plumbing in a new fuel selector, and instead of
having my fuel return (older simmons injection that
has a fuel return) return to the tank, was thinking of
plumbing in a tee in the line just before the fuel
pump. This is because the fuel return is currently
going to one tank, and makes fuel management a chore.
Any reason why I shouldn't do this? Cavatation, etc?
Paul Besing
Bruce(at)glasair.org
PostPosted: Tue May 09, 2006 8:06 pm    Post subject: Fuel Return Tee Reply with quote
Andair has a more elegant solution, a double valve fuel selector. It
switches the return line to the tank from which you are drawing.
Bruce
www.glasair.org
Albert Gardner
PostPosted: Tue May 09, 2006 8:15 pm    Post subject: Fuel Return Tee Reply with quote
This is the method that's being used in the RV-10. The fuel is returned to a
T installed in the line between the fuel selector valve and the fuel filter.
Albert Gardner
RV-10 #422
RV-9A N872RV
RV-10 #40422
jmpcrftr(at)teleport.com
Vapor Lock
Assuming this is a continuous full time re-circulation. Fuel gets
heated as it circulates through the fuel injection components up
front. It needs to go to the tank to cool. It can get hot enough
that the boost pump doesn't create enough pressure to overcome the
vaporization.
I'm not familiar with the Simmons injection you mentioned. This is a
typical question/problem for alternate engine installations. These
typically have a constant volume or high pressure pump that has a
high recirc volume through the pressure regulator. In this case we
have to use something like the Andair Duplex (six port) fuel valve so
the recirc goes to the tank it came out of. This valve eliminates
the fuel management issue you talked about. The valve is
unfortunately very expensive at over
$300. http://www.andair.co.uk/system/index.html
Mike
Mike McGee, RV-4 N996RV, O320-E2G, Hillsboro, OR
13B in gestation mode, RD-1C, EC-2
Paul Besing
PostPosted: Tue May 09, 2006 8:32 pm    Post subject: Fuel Return Tee Reply with quote
Yeah, I saw that, very pricey, and I only have one
line plumbed to one tank. I'd have to spend the $400
on the selector, remove the right tank, take the
sender bracket off, plumb a return line to the tank,
etc, etc. I thought it was much easier just to plumb
the return back into the system, instead of the tank
it comes from.
Paul Besing
fuel selector. It
are drawing.
Bruce
www.glasair.org
Albert Gardner
PostPosted: Tue May 09, 2006 8:46 pm    Post subject: Fuel Return Tee Reply with quote
I think this will link to a picture of the assembly out of the plane.
Builder is Larry Rosen.
http://lrosen.nerv10.com/Construct/Log/Fuselage/Fuel_lines/slides/2006-02-27
-fuel-27.html
Albert Gardner
RV-10 #422
RV-9A N872RV
RV-10 #40422
PostPosted: Tue May 09, 2006 9:38 pm    Post subject: Fuel Return Tee Reply with quote
It's only about 1 GPH that returns..wouldn't 1 GPH
mixing with 9 GPH cool enough?
Vapor Lock
components up
get hot enough
to overcome the
vaporization.
pump that has a
In this case we
port) fuel valve so
valve eliminates
valve is
Mike
<pbesing(at)yahoo.com>
of
chore.
etc?
>Paul Besing
browse
Subscriptions page,
FAQ,
Admin.
retasker(at)optonline.net
PostPosted: Tue May 09, 2006 10:17 pm    Post subject: Fuel Return Tee Reply with quote
Yes, but depending on how much fuel is consumed on each trip around the
circuit the fuel may get very hot and then you have the makings of a
vapor lock problem. If you don't want to replumb it to return fuel back
to the source tank, any chance you can add a small header tank? That
would allow more volume of fuel to dissipate any heat from the pass
through the fuel circuit.
On the other hand, if a significant portion of the pumped fuel is
consumed each time around the circuit, it may be no problem at all.
My $0.02. I have one of the $300 Andair fuel valves Wink .
Dick Tasker
it comes from.
Paul Besing
>fuel selector. It
>are drawing.
>Bruce
>www.glasair.org
PostPosted: Tue May 09, 2006 11:16 pm    Post subject: Fuel Return Tee Reply with quote
The most critical time for vapor lock is after you rotate on takeoff after a
long time at idle power. There's only 2 ways to reduce the possibility of
vapor lock, decrease the temperature of the fuel or raise the pressure in
the fuel line. We also have to consider the different locations where vapor
lock can occur. The most common is the low/suction side of the engine driven
fuel pump. If the fuel or pump temperature is at it's vapor point, the
pressure drop at the fuel pump will vaporize it and no more pumping. That's
the condition the electric fuel pump is likely to correct. The next most
likely is the fuel servo, this is already seeing the high pressure of the
engine pump, so turning on the electric pump is not likely to have much
beneficial effect. Your best choice here is, a thermal brake between your
servo and the engine induction housing (fiberglass/wood gasket/spacer) or
cooling the servo case with fuel flow. This condition is what the fuel
return line is designed to cure. If the engine is already at full power the
extra 1 gph of a return line will have little effect. So the return line can
only be beneficial from a preventative standpoint. It's designed to cool the
servo during long taxi periods at idle power. There might be some benefit to
running the engine at mid power levels after a long taxi before takeoff on
hot days for 3-5 minutes to cool the servo with fuel if you don't have a
return line.
Vapor lock in the feed line from the servo to the spider is only an issue
for hot starts. Some FI systems have a purge line on the distribution spider
to solve this issue.
One other area of concern is that our diaphragm type of engine fuel pumps
have a failure mode that will block the fuel line and not allow fuel to
reach the servo even with the electric pump operational. Some builders have
installed a second faucet type pump with check valve and plumbed to a T
right at the main inlet of the fuel servo. This pump is always left on. Gear
driven fuel pumps (Lear-Romec) don't have this failure mode
Bruce
www.glasair.org
rv8ch
PostPosted: Tue May 09, 2006 11:20 pm    Post subject: Fuel Return Tee Reply with quote
Paul,
Clearly the best way is the Andair valve that directs
the return to the same tank as the source. If that's
off the table, I would just make sure that after you
fill up, you select the tank that has the return line.
After burning a few gallons, then you should be ok to
switch tanks, keeping in mind the tank without the
return will empty a bit more quickly.
I would not return the hot, possibly vapor laden fuel
to the intake of the fuel pump, since as you suggested,
cavitation and then vapor lock can happen.
I've read somewhere that fuel issues are one of the
leading cause of accidents in the first 10 hours of
flight in experimental aircraft, so this is an area
where I feel it is worth a lot of extra effort to
make it bulletproof. I know that fuel delivery on
my Subaru powered RV8 has been the single largest
time sink for me.
Mickey Coggins
http://www.rv8.ch/
#82007 finishing
Mickey Coggins
http://www.rv8.ch/
pitts_pilot(at)bellsouth.
PostPosted: Wed May 10, 2006 6:01 am    Post subject: Fuel Return Tee Reply with quote
Since we're talking servo's here, then we should only discuss the
problem with fuel injection with this thread.
Why do you think this is so?? If you suffer vaopr lock at rotation, you
would just roll out .... unless you're just cutting the runway length a
little close!!! Sad
the fuel line.
Agreed!
beneficial effect.
I kinda disagree .... If you plumb the pumps in parallel, then I agree.
But I don't know why you'd do that. If plumbed in series, depending on
the head pressure and temperature at the electric pump, you still may
have a risk. If you plumb the electric pump so it's low and inside the
cockpit, you've pretty much conquered the vapor lock possibility.
But experiencing vapor lock usually precludes starting the engine.
Here's the rub. You can use the electric pump to overcome the vapor
problem and get cool fuel into the engine compartment ..... but you also
risk the possibility of flooding.
Not true. It's designed to return excess fuel to the tank instead of
creating an excessively rich condition. Not all fuel servo's have a
return line.
return line.
I doubt it. If the engine is running, then the system is supplied with
cooler fuel already and the servo is under pressure ..... hence no vapor
problem.
OK.
You'll have to tell me what that is. Pressure on the inlet to the
mechanical pump will flow through the two reed valves with no problem.
Some builders have
Please tell me what that failure mode is. AFAIK, what you describe is a
reaction to a non-existent problem.
Linn
Bruce
www.glasair.org
PostPosted: Wed May 10, 2006 6:08 am    Post subject: Fuel Return Tee Reply with quote
Paul,
Maybe not the best way INMHO, but a good idea.
If that's
That's not a good idea. If you start with full tanks and (because
you're human) don't have the selector on the 'return' tank, you'll just
pump the return fuel overboard.
If you have fuel flow, then there's no vapor lock problem to begin with.
In a closed loop system where the hot fuel is returned to the input
side of the mechanical pump, it's being mixed with cool fuel from the
tank, so vapor lock shouldn't be an issue at that point.
time sink for me.
I suspect that the issues you're referring to are caused by trash in the
system from construction or deterioration of materials used in hte
system. Then comes issues relating to pickup of the fuel in the tank,
fittings that aren't tight, and other assembly errors. At the bottom of
my list would be the yo-yo that doesn't fill it up!
Linn
dan.beadle(at)inclinesoft
PostPosted: Wed May 10, 2006 6:45 am    Post subject: Fuel Return Tee Reply with quote
I checked prices - these are over $500. Very nice. Seems like the best
solution.
Recirculating warm fuel thru a T doesn't seem like a great solution for
cooling servo to get a Hot Start to work. On my C414, they are very
difficult to start on a warm Nevada day after shutting down for 15-60
minutes. Exchanging warm fuel from the servo for "cold" fuel from the tanks
seems the way to go.
Looking at the specs for the Andair valve, it says it is suitable for 200HP
engines. They don't have a flow rate spec'ed. I am going with a 210. Is
there enough margin there? What size fuel lines are you guys using for
IO390s?
Dan Beadle
rvbuilder(at)sausen.net
PostPosted: Wed May 10, 2006 2:22 pm    Post subject: Fuel Return Tee Reply with quote
Actually, there is a big difference between recirculating the fuel =
from the engine and what the whole Airflow Performance boost pump setup =
does. The AP boost pump setup is full of check valves and bypasses that =
are mainly to protect the pump and make sure there is always fuel going =
to the engine. It does not recirculate anything from the fuel injection =
servo.
Michael Sausen
RV-10 #352 Working on Fuselage
