RayStL
Posted: Mon Feb 07, 2011 3:41 pm Post subject: Battery box being demanded |
Help. I have a homebuilt CH701. A DOT Inspector (Canada) is trying to force me to retrofit a battery box on my sealed Power Sonic battery attached to the cockpit side of the firewall. I need to convince him it complies with an applicable aviation standard. I am having a hard time finding anything concrete out there. Any suggestions?
Thanks.
--ray
_________________ Ray St-Laurent
701/Pegastol wings/Suzuki engine |
Flydad57(at)neo.rr.com Guest
Posted: Mon Feb 07, 2011 5:06 pm Post subject: Battery box being demanded |
Would it be reasonable for you to ask the good inspector the applicable
aviation standard to which you were in violation? This would save some time
and would give him the opportunity to "disengage".
Just askin'.
Bob Taylor
TigerCub N657RT
Sent: Monday, February 07, 2011 6:41 PM
To: <aeroelectric-list(at)matronics.com>
Subject: Battery box being demanded
Thanks.
--ray
Ray St-Laurent
http://forums.matronics.com/viewtopic.php?p=330059#330059
RayStL
Posted: Mon Feb 07, 2011 9:46 pm Post subject: Re: Battery box being demanded |
Here are his words...
"you have not provided specific "accepted aviation standard practices" references or documentation required to meet Canadian Aviation Regulation Standard 549.5(b). "
I am not sure what the FAR equivalent is.
--ray
RayStL
Posted: Tue Feb 08, 2011 5:07 am Post subject: Re: Battery box being demanded |
An STC of an equivalent installation might be the easiest way to convince. I think that would be an unvented AGM inside the cabin. I see there are some under seat Cub STC's that might do. Does anyone have details. If so then I just need to convince him that my battery is equivalent to that specified.
--ray
Float Flyr
Posted: Tue Feb 08, 2011 5:30 am Post subject: Battery box being demanded |
The problem is that specs here in Canada seldom if ever keep up with
technology. The best thing to do is get yourself a box similar to either
Tupperware or Rubbermaid which loosely fits the battery then add into the
box some Styrofoam as bump protection. What he is looking for is
containment of the acid and a possible short circuit in case of an accident.
An installation which can withstand a minimum of 3G forward acceleration is
also important for anything in or behind the panel.
Noel
_________________ Noel Loveys
Kitfox III-A
Aerocet 1100 Floats |
klehman(at)albedo.net Guest
Posted: Tue Feb 08, 2011 5:36 am Post subject: Battery box being demanded |
Would he be amenable to discussing this with an MDRA inspector since
MDRA does most of the amateur built Canadian inspections? My MDRA
inspector never batted an eyelash even with one of my AGM batteries
sitting on its side on the cockpit side of the firewall. An MOT
inspector may not be familiar with AGM technology as they don't usually
do initial inspections.
I was under the impression that a battery vent port had to be routed
overboard when it was in a battery box?? Impossible to do when the
battery doesn't even have a vent port. Does Concord say anything about
boxes for their certified AGM batteries?
When dealing with bureaucracy it might be just as well to fabricate a
temporary box but then I suppose this guy might want flow through box
venting if he looks at it closely. Remove the electrical system
temporarily? ;(
Ken
On 2/7/2011 6:41 PM, RayStL wrote:
"RayStL"<raystl(at)nbnet.nb.ca>
Thanks. --ray
Float Flyr
Posted: Tue Feb 08, 2011 6:02 am Post subject: Battery box being demanded |
Ok here it is:
549.5 Construction
(a) Aircraft, including those supplied in kit form, will be designated as
amateur-built aircraft, where the major portion of the aircraft (more than
50%) is fabricated from raw material and assembled by an individual or a
group of individuals on a non-commercial, non-production basis for
educational or recreational purposes
Information Note:
(Ref. AMA 549/1A, para. 5).
(b) Methods of fabrication and assembly, and workmanship shall be
appropriate and should conform to accepted aviation standard practices.
| Quote: | From this what he wants to see is the fact you and any other owners of the
kit did more than 50 % of the construction of the plane. If the Plane is a
kit then all you need is the paperwork from the kit supplier stating that
more than 50% of the work to build must be done by the builder to complete
the plane. Most, if not all U.S. kits will pass this requirement.
Noel
Kitfox III-A
Float Flyr
Posted: Tue Feb 08, 2011 6:04 am Post subject: Battery box being demanded |
Just noticed in your case you have a CH 701 with Pegastol wings... You may
need two certificates for the 50% rule.
Noel
Kitfox III-A
bakerocb
Posted: Tue Feb 08, 2011 8:10 am Post subject: Battery box being demanded |
2/8/2011
Hello Fellow Builders,
Ray St-Laurent wrote: "I need to convince him it complies with an
applicable aviation standard."
Ray, you might go through this Concorde RG7 SERIES AIRCRAFT BATTERY
OWNER/OPERATOR MANUAL for aircraft RG batteries and find enough evidence to
convince your inspector. Please let us know how you make out.
http://www.concordebattery.com/otherpdf/5-0324-rg-manual.pdf
Bob Taylor wrote: "Would it be reasonable for you to ask the good inspector
the applicable
aviation standard to which you were in violation?"
and Ray responded: "Here are his words..."you have not provided specific
to meet Canadian Aviation Regulation Standard 549.5(b)."
Here is what Part V - Airworthiness Manual Chapter 549 - Amateur-Built
Aircraft
549.5(b) says:
http://www.tc.gc.ca/eng/civilaviation/regserv/cars/part5-standards-549-sub-a-1785.htm
Note that the word "experimental" does not appear in this Part V. I have two
questions:
A) I wonder if the very first composite construction amateur built aircraft
in Canada met their
then existing "accepted aviation standard practices" ?
B) I wonder if Ray's Suzuki engine meets Canadian "accepted aviation
standard practices"?
I am grateful to the EAA and many amateur building predecessors here in the
USA that I don't have to abide by Canadian regulations.
'OC' Baker Says: "The best investment we can make is the time and effort to
gather and understand knowledge."
PS: I have an Odyssey PC-680 RG battery in my KIS TR-1 baggage compartment
behind the right seat. No battery box per se, just sound structural
mounting.
Time: 05:06:44 PM PST US
Subject: Re: Battery box being demanded
Just askin'.
Bob Taylor
TigerCub N657RT
Thanks.
--ray
Ray St-Laurent
RayStL
Posted: Tue Feb 08, 2011 8:44 am Post subject: Re: Battery box being demanded |
Thanks for your help so far.
Let me give more background. The aircraft has been flying for over 3 years. The MDRA inspector was fine with the battery.
My aircraft has been grounded since the inspection last August. There were 2 issues they had. The battery is one. The second was because I have a variable pitch prop (Ivo) regulations say I need a manifold pressure gauge. My engine is a ‘modern’ car engine that continuously measures manifold pressure, throttle position, rpm, air temperature, exhaust oxygen and uses that to control fuel and ignition. A separate manifold gauge would be a distraction at best.
Yes it would have been easier to knuckle under to their inappropriate requests. (I would like to Nuckolls them. Grrr.)
They finally relented on the manifold pressure issue. Only the battery issue remains.
The easiest way is to find something approved that will fit in their pigeon hole. Otherwise I have been told I have go through a full technical analysis (and test?) to justify it.
On a homebuilt!!!???
sportav8r(at)gmail.com Guest
Posted: Tue Feb 08, 2011 9:49 am Post subject: Battery box being demanded |
Ridiculous-sounding stuff on their part. I'm guessing that later removal of said battery box would not constitute a "major change." More like ongoing experimentation in your experimental aircraft. Still a hassle to build the box in the first place. When my pink Gill battery was replaced by an Odyssey, the loss of the battery box was not a reported event. So it shall remain.
-Bill B
On Tue, Feb 8, 2011 at 11:44 AM, RayStL <raystl(at)nbnet.nb.ca (raystl(at)nbnet.nb.ca)> wrote:
[quote] --> AeroElectric-List message posted by: "RayStL" <raystl(at)nbnet.nb.ca (raystl(at)nbnet.nb.ca)>
Ray St-Laurent
http://forums.matronics.com/viewtopic.php?p=330169#330169
le, List Admin.
Float Flyr
Posted: Tue Feb 08, 2011 9:50 am Post subject: Battery box being demanded |
The section and subsection he quoted you have nothing whatsoever to do with
battery location or installation. Contact the nearest chapter of the RAA (
Recreational Aircraft Association for clarification. Their mandate is not
to keep you out of the air just to make you safe when you do fly.
Noel
Kitfox III-A
terry.mortimore(at)shaw.c Guest
Posted: Tue Feb 08, 2011 10:25 am Post subject: Battery box being demanded |
Hi Ray, I'm curious as to how you got to be dealing with the DOT inspector?
If the MDRA inspector did the final inspection and the airplane was flying, how did the DOT get involved?
Any way of getting the DOT inspector out of the loop by going back to MDRA?
Terry.
RayStL
Posted: Tue Feb 08, 2011 11:32 am Post subject: Re: Battery box being demanded |
MDRA is only involved in the building process. I had an engine failure at a controlled airport. That got DOT’s attention (that’s fair). The cause was from radiant heat cooking my fuel pumps (They have heat shields on them now). They did not snag the revised fuel pump setup but...
The DOT inspector was somewhat annoyed that the MDRA inspector had not flagged the battery. It was clear the DOT inspector had never heard of a sealed lead acid battery, AGM, recombinant gas or any the synonym I could think of.
--ray
Float Flyr
Posted: Wed Feb 09, 2011 5:44 am Post subject: Battery box being demanded |
I wonder why he stated to you the Section V standard... It doesn't jibe. I would ask him again to give the exact standard he wants followed.
With that you can google Canadian Aviation Regulations and download the whole mess in PDF. The first number in the part he wants you to follow is usually written as a capitol roman numeral. The second number is either a 0 or a 2. If it is a 0 then it is a regulation. If it is a 2 it is a standard or method to fulfil the regulation. The third number is the subsection and then the decimal point. After the decimal point is the specific rules in the subsection.
You can also read the cars in more of an organised mode at:
http://www.tc.gc.ca/eng/civilaviation/regserv/cars/menu.htm
I agree with your assessment of the manifold pressure gauge but if they were really sticky on it you could have one installed easily. It the most it would have meant is drilling and welding a boss onto the intake manifold close to the throttle body... there is probably one there already.
I think what he wants to see is a box capable of withstanding a +3G forward impact with the weight of the battery in it and also be able to contain the contents of the battery in the case of an accident. A normal covered plastic battery box... to fit and be properly secured should satisfy him. Crappy tire (a Canadian thing)could probably help.
Noel
Kitfox III-A
Posted: Wed Feb 09, 2011 7:20 am Post subject: Battery box being demanded |
| Quote: | I think what he wants to see is a box capable of withstanding a +3G
The crash safety hold-down rules here
call for 10G of tear-away resistance
for rearward acceleration. For a 25#
SVLA this translates to 250 pounds of
tensile strength for retainers.
We did some studies on 6" strips of
Velcro on 1" wide straps at HBC and
measured tensile strengths in the many
hundreds of pounds depending on how well
the installer 'mashed' the fasteners
together.
On that basis, I've recommended several
times in the past that SVLA batteries
might be strapped down in shallow trays
having lips on the order of 1/2" with
two Velcro closed web-straps. This kind
of attention would indicated if the
battery were aft of crew space.
If the battery is on the forward side of
the firewall, it's not going to be a
missile-hazard.
n801bh(at)netzero.com Guest
RayStL
Posted: Wed Feb 09, 2011 9:15 am Post subject: Re: Battery box being demanded |
Thanks to all have responded. From communications with the DOT inspector, it is clear that the quickest solution will be to reference a STC for a cub or similar that uses an underseat strap down of an AGM battery. I know Concorde has STCs but I have not tracked down yet if that includes elimination of the battery box.
There is a broader, much more disturbing side to this issue. A DOT inspector wants to revoke approval for something that has already passed inspection. The installation has not changed. That means any (Canadian) homebuilt could theoretically revoke approval for any previously approved installation. It also unjustly (I believe) questions the validity of any previous inspection through MDRA.
I know of other Canadian homebuilts using AGMs without battery boxes but I am not about to cite those as examples.
--ray
raymondj(at)frontiernet.n Guest
Posted: Wed Feb 09, 2011 9:49 am Post subject: Battery box being demanded |
I am not familiar with how the Canadian system works, but I assume a
bureaucrat is a bureaucrat. Perhaps the MDRA inspector that approved
the initial inspection would be offended by the DOT inspectors
implication that his work was in someway lacking. Perhaps he might be
motivated to go to bat for you and for HIS reputation. The most likely
way this will be resolved in your favor is if you can get someone else
in the government to bring pressure on the DOT guy to change his opinion.
Raymond Julian
Kettle River, MN
On 02/09/2011 11:15 AM, RayStL wrote:
--ray
Ray St-Laurent
http://forums.matronics.com/viewtopic.php?p=330294#330294
Posted: Wed Feb 09, 2011 10:52 am Post subject: Battery box being demanded |
As far as the battery is concerned though, I think it is a pretty
good idea to have it in a securely mounted corrosion proof box just
for your own good.
What degree and style of "bad" would you expect to
be held at bay by a "corrosion proof box"?
