rickofudall
Posted: Thu Feb 10, 2011 11:54 am Post subject: Operating at maximum weight |
You guys remember that part of your operating instructions that says you'll test the aircraft at max gross weight while in phase 1 testing? You know, buy four bags of sand or cement and put them in the passenger seat and test in all configurations and put this statement in the aircraft's log book, “I certify that the prescribed flight test hours have been completed and the aircraft is controllable throughout its normal range of speeds and throughout all maneuvers to be executed, has no hazardous operating characteristics or design features, and is safe for operation. The flight test was completed under the following conditions: maximum operating weight, style/set of wing or sail, maximum demonstrated airspeed, and minimum demonstrated stall speed.”? You all did that, right? By this discussion, I'd say not.
Rick Girard
Zulu Delta
Mk IIIC
Thanks, Homer GBYM
It isn't necessary to have relatives in Kansas City in order to be unhappy.
- Groucho Marx
Posted: Thu Feb 10, 2011 12:05 pm Post subject: Operating at maximum weight |
Rick, I didn't enter the specific exercise in my log book but I did strap several 80 lb salt bags in the passenger seat fora free excursion before I took a passenger. I didn't want to hurt the salt bags.
BB
On 10, Feb 2011, at 2:29 PM, Richard Girard wrote:
[quote]You guys remember that part of your operating instructions that says you'll test the aircraft at max gross weight while in phase 1 testing? You know, buy four bags of sand or cement and put them in the passenger seat and test in all configurations and put this statement in the aircraft's log book, “I certify that the prescribed flight test hours have been completed and the aircraft is controllable throughout its normal range of speeds and throughout all maneuvers to be executed, has no hazardous operating characteristics or design features, and is safe for operation. The flight test was completed under the following conditions: maximum operating weight, style/set of wing or sail, maximum demonstrated airspeed, and minimum demonstrated stall speed.”? You all did that, right? By this discussion, I'd say not.
Rick Girard
Zulu Delta
Mk IIIC
Thanks, Homer GBYM
- Groucho Marx
Quote: |
| [b]
Posted: Thu Feb 10, 2011 12:36 pm Post subject: Operating at maximum weight |
flight test was completed under the following conditions: *maximum
operating weight*, style/set of wing or sail, maximum demonstrated airspeed,
Rick Girard
Zulu Delta
Mk IIIC
Thanks, Homer GBYM
- Groucho Marx
Checked by AVG - www.avg.com
_________________ John Hauck
Titus, Alabama |
neilsenrm(at)gmail.com Guest
Posted: Thu Feb 10, 2011 12:39 pm Post subject: Operating at maximum weight |
Rick
Yes I did load my plane up with salt bags to gross weight and test flew it. The suprising thing was my lack of understanding how much further forward the CG was with a real person than I had figured with the salt bags. The other suprising think was how much worse it gets with a high thrust line and the extra thrust with the redrive. I did three different maximum weight flight tests with different engine configurations.
Rick Neilsen
Redrive VW Powered MKIIIC
On Thu, Feb 10, 2011 at 2:29 PM, Richard Girard <aslsa.rng(at)gmail.com (aslsa.rng(at)gmail.com)> wrote:
Rick Girard
Zulu Delta
Mk IIIC
Thanks, Homer GBYM
- Groucho Marx
Quote: |
ttp://forums.matronics.com
| [b]
elleryweld(at)aol.com Guest
Posted: Thu Feb 10, 2011 12:41 pm Post subject: Operating at maximum weight |
Rick
I didn't build this particular airplane in fact I am the third owner of it ,it was not my job to do all this testing so I am using the numbers that have been scribed in stone in the paperwork that was included with it
Ellery Batchelder Jr.
