New Stereo Audio Mixer Products
sprocket(at)vx-aviation.c
PostPosted: Tue Feb 15, 2011 10:58 pm    Post subject: New Stereo Audio Mixer Products Reply with quote
Discussed several times over the years on Aeroelectric, audio mixers have matured. In addition to mono audio mixer/audio panel devices and stereo headphone adapters available for some time, Vx Aviation has released a pair of stereo audio mixers in our unique form factor-- the D-sub backshell.
Although we avoid posting too much commercial material to the list, I hope Bob appreciates what we've done here, because it's relevant to what we have debated over the years.
Thanks, Vern Little
Summary of Announcement:
VICTORIA, BC---February 16, 2011---Vx Aviation today announced the
introduction of the first stereo audio mixers designed specifically for
experimental aircraft applications. The AMX-4A and AMX-4B dramatically
simplify and lower the cost of audio system installation in both existing
and new aircraft. Both units are virtually pin-compatible with the
industry-leading AMX-2A monophonic 10 channel miniature audio mixer,
introduced in 2008.
Both the AMX-4A and AMX-4B units provide five independent stereo input
channels. Three channels are fixed-level, designed to connect to audio
sources that have their own volume controls, such as EFIS systems and XM
radios. Two of the channels have screwdriver adjustable audio levels,
providing the flexibility required when connecting to fixed level sources.
Monophonic sources are supported by connecting together the left and right
inputs of any input channel.
The AMX-4A low output version works seamlessly with PS Engineering
intercoms, providing the critical 2 volt peak-to-peak voltage limiting
required that prevents damage to the PS Engineering products. The AMX-4B
high output version has no such limiting and provides up to 12 volts
peak-to-peak drive capability and a gain of 15 decibels, making it
compatible with intercoms that require input amplification or for directly
driving headphones.
<for more information, including photographs and drawings, please see
attached document>
For further inquiries, please contact me. Thank-you.
Vern Little
Vx Aviation
www.vx-aviation.com
AMX-4A-110216.pdf
 Filename:  AMX-4A-110216.pdf
 Filesize:  105.86 KB
 Downloaded:  901 Time(s)
