		cardinalnsb(at)aol.com Guest
				 Posted: Wed Feb 16, 2011 11:16 am    Post subject: follow up shielded wire/hub question |
				My first question needed to be more specific.  My audio panel installation manual shows that the shielded wires are "open" (shield not grounded) at the end where the wires connect to the radio, and the shields are all grounded together at the audio panel.
 If I use a "hub" system, where all avionics go in and then out of the hub, do I keep each shield on a separate pin going in and out of the hub, or do I ground all the shields together going into the hub and then start a set of new shielded wires comng out of he hub (open coming out of the hub) and tie all the shields to ground at the audio panel?
 Thanks for the help, Skip
  |  | - The Matronics AeroElectric-List Email Forum - |  |   |  Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
				 Posted: Thu Feb 17, 2011 7:40 am    Post subject: follow up shielded wire/hub question |
				At 01:50 PM 2/16/2011, you wrote:
   	  | Quote: | 	 		  My first question needed to be more specific.  My audio panel installation manual shows that the shielded wires are "open" (shield not grounded) at the end where the wires connect to the radio, and the shields are all grounded together at the audio panel.
  If I use a "hub" system, where all avionics go in and then out of the hub, do I keep each shield on a separate pin going in and out of the hub, or do I ground all the shields together going into the hub and then start a set of new shielded wires comng out of he hub (open coming out of the hub) and tie all the shields to ground at the audio panel? |
     Exactly where shields go to ground in small
     airplanes is pretty much irrelevant. IF the
     shield is connected at both ends and is obviously
     a return path for signal or power, then carry
     it through the hub on it's own pathway.
     If the shield is not a signal/power pathway,
     connect to common ground in hub (which still
     needs to be carried to shield ground at the
     audio panel)
     FYI . . . when replying to a message lumped
     with others in the 'digest' configuration, please
     trim away all non-relevant text from the message.
    Bob . . .    [quote][b]
