				|  | Matronics Email Lists Web Forum Interface to the Matronics Email Lists
		| Author | Message |
		| frans(at)privatepilots.nl Guest
				|  Posted: Wed Mar 02, 2011 12:12 pm    Post subject: Jacking up a tri gear |   |
				| Just another question:
(Yep, the end of the winter is near, I'm thinking again about flying).
 For my annual I need to take the main wheels of the ground, one at a time.
 What is the best way of doing so? I have the leg fairings installed, so
 I can't use the legs. The area where the leg protrudes from the fuselage
 is curved, so I can't use a piece of wood either. Before I reinvent the
 wheel I would like to hear what others have thought out.
 (In case you are wondering how I built this flying machine: I had a full
 length craddle, and lifted the entire airplane once the gear was ready
 with a hoist. Neither the hoist nor the craddle are available anymore).
 Frans
 | |  |  | - The Matronics Europa-List Email Forum - |  |  |  | Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:http://www.matronics.com/Navigator?Europa-List
		| Back to top |  |
		| jeff(at)rmmm.net Guest
				|  Posted: Wed Mar 02, 2011 12:27 pm    Post subject: Jacking up a tri gear |   |
				|  	  | Quote: |  	  | For my annual I need to take the main wheels of the ground, one at a time.
 Frans,
 This is where I go to place a soft piece of foam then the wood and jack. Works every time.
 Jeff R.  N128LJ Gold Rush
  	  | Quote: |  	  | Before I reinvent the wheel I would like to hear what others have thought out.
 Frans
		| Back to top |  |
		| neveyre(at)aol.co.uk Guest
				|  Posted: Wed Mar 02, 2011 12:50 pm    Post subject: Jacking up a tri gear |   |
				| Hi Franz,
You need a steel tube / bar that is a slip fit into the axle that is about 20'' long, a block of wood and a jack.
 Remove the split pin and slacken the nut.
 Slide the tube into the axle, put a jack under the end of the tube and lift the wheel clear of the ground.
 Run the nut off onto the tube, followed by the wheel and bearings.
 Put the block of wood under the axle and lower the jack. Bingo !
 Refitting is the reverse, slide the tube through the bearings and wheel, along with the nut, slide the assembly into the axle, pick up with the jack, remove the wood block and slide the bearings / wheel onto the axle, run the nut up until it nips.
 Drop the jack, fit new splitpin.
 Nev
		| Back to top |  |
 | You cannot post new topics in this forum You cannot reply to topics in this forum
