tim2542(at)sbcglobal.net Guest
Posted: Wed Feb 23, 2011 10:14 pm Post subject: How should I use the AeroElectric Panel Grounding Hub? |
On 2/23/2011 7:41 PM, jhclarkfl wrote:
| Quote: | -I have read about concerns about grounding avionics through the hub because of current limitations of the individual pins and the potential of exceeding the current capability of the hub and the 4 or 5 20 ga ground wires run to the Forrest of Tabs. Something was also mentioned about all ground wires not being equal such as when a 16 or 18ga wire is split into two 20ga wires for insertion into the hub.
Jack Clark
RV-8A Fuselage
http://www.mykitlog.com/jackclark/
I used Bob's Avionics ground bus and liked it. The only difficulty, and it's no big deal, is the Comm grounds. Both of mine (A210 and 430W) require 18 awg wire. So I just ganged the 18 awg wire into 2 pins with 20 awg wire using solder sleeves. No big deal, easy to do. Nothing else on my panel comes close to the limit for the pins except I do have an electric nose lift (10 amps max) that is not grounded yet. I have been debating putting this on the bus with 3 20awg wires/pins. Bob?
HTH, Tim Andres
