a.s.elliott(at)cox.net Guest
Posted: Tue Feb 22, 2011 7:13 am Post subject: Trim tab slaving? |
Gang:
On my 601XL, the elevator trim tab is not effective enough to trim out all control forces on a full-flap final when the CG is in the front half of the allowed range. Although the remaining elevator forces are light, I would like to be able to trim them away. The trim tab is inset on one side of the elevator, and takes the entire width, minus about 20 mm on each end. Servo is RAC
One option would be to add another trim tab to the other side of the elevator. But to do that I would need some way to slave the two sides together. Does anyone have an idea about how to do that electronically without very high cost, or perhaps some way already exists and I haven't found it? (The elevator design doesn't allow for a simple mechanical connection.)
Another option, of course, would to be to increase the size of the trim tab, either making it full width (probably not too effective - delta area <10%), or extending it aft 20-25 mm (probably would work, but ugly), or both. I might go that way, but thought I'd ask about the saving first.
Andy
Andy Elliott
N601GE/Z601XL/TD/Corvair
298 hrs since 11/08
n801bh(at)netzero.com Guest
Posted: Tue Feb 22, 2011 7:41 am Post subject: Trim tab slaving? |
I vote for extending it aft.. Syncronizing two servos are problematic for sure,
Ben Haas
N801BH
www.haaspowerair.com
Posted: Tue Feb 22, 2011 7:46 am Post subject: Trim tab slaving? |
My RV has tabs on both elevators, each cable-driven by a single servo.
I think it would be needlessly complicated to get two servos married
together at all times. If you didn't do that, you'd have to have some
scheme to make sure they were at least able to be manually
coordinated.
I'd recommend extending the existing tab. You might not need as much
as you think. We regularly just tape a tab on temporarily until we
figure out what size to use.
Dave Saylor
AirCrafters
140 Aviation Way
Watsonville, CA 95076
831-722-9141 Shop
831-750-0284 Cell
On Tue, Feb 22, 2011 at 7:09 AM, Dr. Andrew Elliott <a.s.elliott(at)cox.net> wrote:
| Quote: | Gang:
is RAC
connection.)
Andy
Andy Elliott
298 hrs since 11/08
mrspudandcompany(at)veriz Guest
Posted: Tue Feb 22, 2011 8:14 am Post subject: Trim tab slaving? |
[quote]On my 601XL, the elevator trim tab is not effective enough to trim out all control forces on a full-flap final when the CG is in the front half of the allowed range. Although the remaining elevator forces are light, I would like to be able to trim them away. Andy, Can your existing trim tab be adjusted to go slitely farther than it now goes. I.e., can the actuator be adjusted to give a little more downward deflection to the tab. Since you are on the edge of being in trim this might be a solution without any further mods. Roger [b]
raymondj(at)frontiernet.n Guest
Posted: Tue Feb 22, 2011 8:29 am Post subject: Trim tab slaving? |
Would VGs on the trim tab offer any benefit? Still might be ugly but
quick to try.
Raymond Julian
Kettle River, MN
On 02/22/2011 09:09 AM, Dr. Andrew Elliott wrote:
| Quote: | Gang:
connection.)
saving first.
Andy
Andy Elliott
298 hrs since 11/08
rickofudall
Posted: Tue Feb 22, 2011 8:32 am Post subject: Trim tab slaving? |
Take a look at the wickerbill, otherwise known in the U.S. as the Gurney flap.
Rick Girard
On Tue, Feb 22, 2011 at 9:09 AM, Dr. Andrew Elliott <a.s.elliott(at)cox.net (a.s.elliott(at)cox.net)> wrote:
Gang:
Andy
Andy Elliott
298 hrs since 11/08
tp://forums.matronics.com
Zulu Delta
Mk IIIC
Thanks, Homer GBYM
It isn't necessary to have relatives in Kansas City in order to be unhappy.
- Groucho Marx
BobsV35B(at)aol.com Guest
Posted: Tue Feb 22, 2011 8:35 am Post subject: Trim tab slaving? |
Good Morning Andy,
Have you thought about adding a small angle on the top and bottom of your trim tab?
Some control surfaces experience seperation at the trailing edges. One trick that has been used was to add a small angle to the trim tab or, occasionally, the whole surface to increase effectiveness. Supposedly, if the air is separating at that point, the angles create very little additional drag and do a good job of increasing affectivity. That was how Morane-Saulnier solved the problem on their Paris Jet 760.
Happy Skies,
Old Bob
In a message dated 2/22/2011 10:15:39 A.M. Central Standard Time, mrspudandcompany(at)verizon.net writes:
| Quote: | On my 601XL, the elevator trim tab is not effective enough to trim out all control forces on a full-flap final when the CG is in the front half of the allowed range. Although the remaining elevator forces are light, I would like to be able to trim them away. Andy, Can your existing trim tab be adjusted to go slitely farther than it now goes. I.e., can the actuator be adjusted to give a little more downward deflection to the tab. Since you are on the edge of being in trim this might be a solution without any further mods. Roger
List href="http://www.matronics.com/Navigator?AeroElectric-List">http://www.matronics.com/Navigator?AeroElectric-List
ms.matronics.com/">http://forums.matronics.com
tp://www.matronics.com/contribution">http://www.matronics.com/contribution
glastar(at)gmx.net Guest
Posted: Tue Feb 22, 2011 8:38 am Post subject: Trim tab slaving? |
Andy,
there might be another way, on the Glastar a similar issue exists
especially for TD's. Two ways did help, first one was having a tape over
the hinge line between HS and Elevator, this did increase effectiveness
(not sure the 601 is using hinges?) Then another was to add some vortex
generator in front of the tab (lower side) increasing effectiveness of
the tab as well.
Werner
On 22.02.2011 16:09, Dr. Andrew Elliott wrote:
| Quote: | Gang:
andrew.d.zachar(at)gmail. Guest
Posted: Tue Feb 22, 2011 9:13 am Post subject: Trim tab slaving? |
A T-strip would most effectively increase the hinge moment of the tab, thus increasing it's effectiveness.
Be careful though, messing with hinge-moments on a surface so far away from the elevator hinge line can quickly get you into trouble flutter-style if you don't have some flutter analysis to back it up.
(Also, a t-strip on the tab would also increase the hinge moments on the elevator resulting in higher longitudinal pitch forces.)
I'd stick with increased tab travel or second tab on the other elevator.
On Tue, Feb 22, 2011 at 11:23 AM, rayj <raymondj(at)frontiernet.net (raymondj(at)frontiernet.net)> wrote:
| Quote: | --> AeroElectric-List message posted by: rayj <raymondj(at)frontiernet.net (raymondj(at)frontiernet.net)>
Would VGs on the trim tab offer any benefit? Still might be ugly but quick to try.
Raymond Julian
Kettle River, MN
| Quote: | Gang:
connection.)
saving first.
Andy
Andy Elliott
298 hrs since 11/08
-List" target="_blank">http://www.matronics.com/Navigator?AeroElectric-List
le, List Admin.
Andrew Zachar
andrew.d.zachar(at)gmail.com (andrew.d.zachar(at)gmail.com)
40950(at)rv10.net Guest
Posted: Tue Feb 22, 2011 7:20 pm Post subject: Trim tab slaving? |
Dr Elliot,
Adjust / extend the throw or extend the trim tab chord with a temporary tab, which ever is more convenient, and measure the effect. We used to use simple hanging scales like those to weight small fish to measure stick forces at repeatable flight conditions. Baseline the forces at the desired landing configuration, weight, and CG location first. Make the tab mods and analyze the results. If there is no noticeable change then there may be some flow separation on the underside of the elevator as others have suggested that has contributed to the problem. Elevator seals and/or vortex generators at or forward of the elevator hinge line area might help. I would not entertain the complexity of synchronizing trim motors. Too hard.
Once you find what works the best, be sure and test the rest of the trim envelope at various speeds and CG/wt conditions to ensure flying qualities overall are still ok. Then construct a permanent change and verify via a retest of the same conditions. Then publish findings to all.
Tom
Sent from my iPad
On Feb 22, 2011, at 9:09 AM, " Dr. Andrew Elliott" <a.s.elliott(at)cox.net (a.s.elliott(at)cox.net)> wrote:
Gang:
Andy
Andy Elliott
298 hrs since 11/08
Posted: Tue Feb 22, 2011 7:39 pm Post subject: Trim tab slaving? |
Dr Elliot,
Tom
Gang:
Andy
Andy Elliott
298 hrs since 11/08
bakerocb
Posted: Wed Feb 23, 2011 4:27 am Post subject: Trim tab slaving? |
2/23/2011
Hello Andy, Is it possible to reduce the length of the lever arm between the
pushrod end and the trim tab surface thereby gaining increased movement of
the trim tab arc for each longitudinal movement of the pushrod?
'OC' Baker Says: "The best investment we can make is the time and effort to
gather and understand knowledge."
Time: 07:13:04 AM PST US
From: " Dr. Andrew Elliott" <a.s.elliott(at)cox.net>
Subject: Trim tab slaving?
Gang:
is RAC
connection.)
Andy
Posted: Wed Feb 23, 2011 11:41 am Post subject: Trim tab slaving? |
Hi Andy-
For what it's worth, I'd suggest there are a couple questions to answer prior to modifying your plane. You may have already run these issues to ground, and if so please disregard the first portion of this note. The first question is, is this trait common to the design? If it is not a common issue, I would suggest verifying your ASI operation / calibration and CG calculations prior to making any changes.
The other observation is to be aware of the effect of increased up trim authority on go around performance. There is the possibility that using increased nose up pitch trim for a low power or power off gliding situation could lead to unexpectedly (startlingly?) high pitch up tendencies when go around power is applied.
YMMV-
| Quote: | Time: 07:13:04 AM PST US
Gang:
is RAC
connection.)
Andy
Andy Elliott
298 hrs since 11/08
Glen Matejcek
email(at)jaredyates.com Guest
Posted: Wed Feb 23, 2011 7:14 pm Post subject: Trim tab slaving? |
Some airplanes also benefit from a little ballast in the baggage compartment. Yours might be a candidate for 25 pounds of kitty litter, which can also come in handy if you really need to pee.
On Wed, Feb 23, 2011 at 2:37 PM, Glen Matejcek <aerobubba(at)earthlink.net (aerobubba(at)earthlink.net)> wrote:
[quote] --> AeroElectric-List message posted by: Glen Matejcek <aerobubba(at)earthlink.net (aerobubba(at)earthlink.net)>
Hi Andy-
YMMV-
>From: " Dr. Andrew Elliott" <a.s.elliott(at)cox.net (a.s.elliott(at)cox.net)>
>Gang:
>is RAC
>connection.)
>Thanks,
>Andy
>Andy Elliott
>298 hrs since 11/08
Glen Matejcek
le, List Admin.
