Posted: Sun Feb 27, 2011 7:50 am Post subject: seatbelt bolt bushings |
Does anyone know where in the kit the aluminum tubing is for making the bushing which go through the selt belts and over the bolts which fasten the seatbelts to the airframe??
AirMike
Posted: Sun Feb 27, 2011 9:02 am Post subject: Seatbelt bolt bushings |
I am not sure of the size, but you surely have a lot of scrap aluminum tubing (fuel, brake, pitot, etc.) that you will use for this application. Just cut a few pieces from the tubing with a band saw. Cut carefully, as they are easy to lose when they are so small. Measure with your harbor freight micrometer.
_________________ See you OSH '18
Q/B - sold. |
daveleikam(at)wi.rr.com Guest
Posted: Sun Feb 27, 2011 10:47 am Post subject: seatbelt bolt bushings |
I went to the hardware store and bought some SS tubing with the correct ID and OD and cut it to fit. The plans say to drill out the aluminum tubing supplied but that was a bit cumbersome.I did not find anything in the kit which had the correct ID for the bushings you speak of.
David Leikam
RV10
N89DA
On Feb 27, 2011, at 9:44 AM, John Gonzalez wrote:
| Quote: | Does anyone know where in the kit the aluminum tubing is for making the bushing which go through the selt belts and over the bolts which fasten the seatbelts to the airframe??
Posted: Sun Feb 27, 2011 7:59 pm Post subject: seatbelt bolt bushings |
That's exactly what I found too, either too big ID or too large or too small OD
Subject: Re: seatbelt bolt bushings
Date: Sun, 27 Feb 2011 12:44:44 -0600
David Leikam
RV10
N89DA
[quote]Does anyone know where in the kit the aluminum tubing is for making the bushing which go through the selt belts and over the bolts which fasten the seatbelts to the airframe??
http://forums.matronics.com
