penetrating oil
daveleikam(at)wi.rr.com
PostPosted: Sun Feb 27, 2011 6:49 am    Post subject: penetrating oil Reply with quote
This is a bit off subject, but a while ago there was some suggestions for using MEK and something else I think for a good rusty bolt penetrating liquid.
Can anyone forward me the thread or suggest what the other ingredient was?
Thanks!
PS
My inspection is set for this Wednesday Smile
David Leikam
RV10
N89DA
Kellym
PostPosted: Sun Feb 27, 2011 12:49 pm    Post subject: penetrating oil Reply with quote
IIRC it was either brake fluid or transmission fluid. I'll search my
archives to see what I can find.
Thanks!
PS
David Leikam
RV10
N89DA
Kelly McMullen
KCHD
davidsoutpost(at)comcast.
PostPosted: Sun Feb 27, 2011 2:58 pm    Post subject: penetrating oil Reply with quote
Get yourself a can of Kroil. This stuff is amazing. http://www.kanolabs.com/
David Clifford
RV-10 Builder
Howell, MI
Kelly McMullen
PostPosted: Sun Feb 27, 2011 4:39 pm    Post subject: Penetrating oil Reply with quote
This is the information you were looking for.
Machinist's Workshop magazine tested penetrants for break out torque on rusted nuts. They arranged a subjective test of all the popular penetrants with the control being the torque required to remove the nut from a "scientifically rusted" environment. The results are as follows;
Penetrating oil..... Average load
None ............ ......516 pounds
WD-40 ................238 pounds
PB Blaster ............214 pounds
Liquid Wrench ..... 127 pounds
Kano Kroil ............106 pounds
ATF-Acetone mix....53 pounds
The ATF-Acetone mix was a "home brew" mix of 50-50 automatic transmission fluid and acetone.
#avg_ls_inline_popup{position: absolute;z-index: 9999;padding: 0px 0px;margin-left: 0px;margin-top: 0px;overflow: hidden;word-wrap: break-word;color: black;font-size: 10px;text-align: left;line-height: 130%;} [quote][b]
Kelly McMullen
A&P/IA, EAA Tech Counselor
KCHD
PostPosted: Sun Feb 27, 2011 8:05 pm    Post subject: Penetrating oil Reply with quote
That's what I was looking for thanks.
David Leikam
RV10
N89DA
On Feb 27, 2011, at 6:36 PM, Kelly McMullen wrote:
[quote]This is the information you were looking for.
chuck(at)chuckdirect.com
PostPosted: Mon Feb 28, 2011 10:31 am    Post subject: Penetrating oil Reply with quote
I use the acetone and atf and always thought it superior to all the other commercial stuff. Guess it is.
Chuck
From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Kelly McMullen
Sent: Sunday, February 27, 2011 4:36 PM
Subject: Penetrating oil
None ............ .....516 pounds
PB Blaster ...........214 pounds
Kano Kroil ...........106 pounds
