david steade
Posted: Mon Mar 07, 2011 4:07 am Post subject: Clearance oil cooler to nose leg |
Hi All
I have just fitted the oil cooler into the duct on my tri-gear XS. To improve the cooling I have lowered the cooler by two inches as suggested in past posts.
The clearance between the steel tube of the nose leg and the bottom of the radiator is now
3-1/4 inches and I'm wondering if this is enough.
If anyone has any experience in this area I would appreciate any advice
David Steade
_________________ David Steade |
Ivor Phillips
Posted: Mon Mar 07, 2011 9:50 am Post subject: Clearance oil cooler to nose leg |
Hi David
Just measured mine and its 3 1/2 to the nose leg with a 2 inch drop for the oil cooler,
I have the springs fitted instead of the bungi cord, but you also have the steel safety
cable to prevent contact in a heavy landing event,
regards
Ivor
G-IVER
On 7 March 2011 12:03, Steade <steade(at)btinternet.com (steade(at)btinternet.com)> wrote:
[quote] Hi All
David Steade
arget="_blank">http://www.matronics.com/Navigator?Europa-List
ttp://forums.matronics.com
budyerly(at)msn.com Guest
Posted: Mon Mar 07, 2011 11:46 am Post subject: Clearance oil cooler to nose leg |
<?xml:namespace prefix="v" /><?xml:namespace prefix="o" /><![endif]--> You should be fine. Before the final fit of the cowl, check the clearance for that too.
Bud Yerly
Tech support.
