		david steade
				 Posted: Mon Mar 07, 2011 3:51 pm    Post subject: Exhaust clearance |
				Hi All
  A bit more guidance please . Now I'm fitting  the exhaust to my Tri-gear. Its the latest oval design. The heat shield on  mine is very close to the nut on the sump banjo fitting.
  Is this normal? What sort of clearance are other builders  getting in this area?
  David Steade
  |  | - The Matronics Europa-List Email Forum - |  |   |  Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
  _________________ David Steade |
		jeff(at)rmmm.net Guest
				 Posted: Mon Mar 07, 2011 6:55 pm    Post subject: Exhaust clearance |
				David,Mine was the same way. Don't worry about that as much as dropping the tunnel under it for more than called for clearance. It's the key to proper tri-gear cooling.
  Jeff R.  N128LJ Gold Rush
 On Mar 7, 2011, at 5:31 PM, Steade wrote:
  	  | Quote: | 	 		  Hi All
 David Steade
 href="http://www.matronics.com/Navigator?Europa-List">http://www.matronics.com/Navigator?Europa-List
		Rocketman
				 Posted: Tue Mar 08, 2011 7:57 am    Post subject: Exhaust clearance |
				David,
 Mine was almost touching the bolt, so I simply dimpled the shield about
 1" diameter, and all is well...
 Jeff - Baby Blue
 On 3/7/2011 5:31 PM, Steade wrote:
  	  | Quote: | 	 		   Hi All
  this area?
  David Steade
