BobbyPaulk(at)comcast.net Guest
Posted: Tue Mar 15, 2011 3:27 pm Post subject: Jabiru |
Martin,
I checked the carb when I received it and found it came with a 250 in lieu of a 255 main jet. It would not turn up for the previous owner and I believe it was due to being too lean. I went up in size slowly watching EGT and CHT's. I ordered a 260 main jet from Pete and installed it. I also ordered a 290 needle jet and bored it to 295.
I have changed jets so many times I don't even pull the carb off the engine any more. i think it is about as close to being right as I can get it.
bobby
116 hrs.
| | - The Matronics JabiruEngine-List Email Forum - | | | Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
http://www.matronics.com/Navigator?JabiruEngine-List |
aerobiz1(at)gmail.com Guest
Posted: Tue Mar 15, 2011 4:15 pm Post subject: Jabiru |
Hi Bobby,
There are a few more mods that can be made, but not necessary maybe in your application.
These include drilling out the idle air bleed (which may entail upping the idle jet to #45) drilling out the main airbleed and the emulsion tube holes and even the jet in the float bowl that feeds the 'choke' circuit. Also placing a small washer under the clip on the needle will richen the mixture in cruise.
But I really think that the problems are poor mixture distribution due to the manifold design, sometimes helped by angling the carb.
Martin
On Wed, Mar 16, 2011 at 9:24 AM, <BobbyPaulk(at)comcast.net (BobbyPaulk(at)comcast.net)> wrote:
[quote]Martin,
bobby
116 hrs.
ist" target="_blank">http://www.matronics.com/Navigator?JabiruEngine-List
tp://forums.matronics.com
plus2s
Posted: Tue Mar 15, 2011 6:36 pm Post subject: Jabiru |
Have you checked the Needle & seat in the carb ?
The early engines used the same as the 4 cyl but has since been upgraded to a larger size to allow more fuel flow.
Keith
--- On Wed, 16/3/11, Martin Hone <aerobiz1(at)gmail.com> wrote:
| Quote: | From: Martin Hone <aerobiz1(at)gmail.com>
Subject: Re: Jabiru
To: jabiruengine-list(at)matronics.com
Date: Wednesday, 16, March, 2011, 1:11 PM
Hi Bobby,
not necessary maybe in your application.These
mixture in cruise.
Martin
at 9:24 AM, <BobbyPaulk(at)comcast.net>
wrote:
Martin,
bobby
116 hrs.
ist"
