		| Author | Message |
		| frans(at)privatepilots.nl Guest
				|  Posted: Thu Mar 17, 2011 5:03 am    Post subject: Will Daniell's wing - not as bad as I first  though |   |
				| On 03/16/2011 06:16 PM, William Daniell wrote:
  	  | Quote: |  	  | Phew “things are never as good or as bad as they seem at first sight” - it wasn’t as bad as I thought it might be…well not bad at all really.
 Just remember that the strength comes from the glass, not the wood. The
 wood is there just to keep the glass layers on the bottom and top of the
 spar separated, so that all spar bending forces are converted into
 compression and tension forces acting on these glass layers.
 Apart from the Redux I think in this case I would reinforce the affected
 area with two or three layers of uni tapered down over the surface just
 to restore the original tension strength. Redux is a nice filler but I
 think the tension strength might leave something to be desired.
 Frans
		| Back to top |  |
		| wdaniell(at)etb.net.co Guest
				|  Posted: Thu Mar 17, 2011 5:42 am    Post subject: Will Daniell's wing - not as bad as I first  though |   |
				| Frans
 Yes I shared your concern.  My heart-failure wasn't over the wood.  It was
 over the bite that I took out of the upper spar cap.  I think that I
 remember someone telling me that something like 90% of the load is carried
 in the top and bottom 10% of the spar - or something pretty close to that.
 Maybe some wiser head can clarify or confirm this statement.
 So yes the advice from Bud and the UK is:
 A.  there is plenty of strength in this area
 B.  Place a 6 ply over lapping bid +/-45 so restore the strength of the root
 plies on the front face of the spar.
 Will
		| Back to top |  |
