Ron Schreck
Joined: 10 Jan 2006 Posts: 94 Location: Gold Hill, NC
Posted: Thu May 11, 2006 1:16 pm Post subject: Tail Wheel Woes |
Hi all,
I had an incident last week that really got my attention. Upon landing,
when I lowered my RV-8's tail wheel to the runway the tail popped back
up suddenly and when it came down again the airplane made a sudden
20-degree left turn off the runway. My neighbor was watching and he
said he saw the tail wheel spinning around 360 degrees (on the vertical
axis) after it bounced the first time. Post-incident autopsy revealed
that the spring-loaded pin that locks the tail wheel was stuck in the
retracted position. I removed the pin, polished it and carefully filed
the pin hole and lubricated the assembly. It works fine, for now, but I
am concerned that the airplane veered so suddenly just because the tail
wheel was apparently unlocked at touchdown. I would assume that air
loads would fix it in the trail position and once contacting the runway
that the castor would do the same. I'm a little gun-shy now since I
can't explain why the airplane reacted as it did. I would feel a bit
better if others have had similar problems and I would be really excited
if someone has a solution to my problem. What say you?
Ron Schreck
RV--8 "Miss Izzy"
Gold Hill Airpark, NC
luckymacy(at)comcast.net Guest
Posted: Thu May 11, 2006 1:39 pm Post subject: Tail Wheel Woes |
sort of...
without know how it affected them, the woodruff key is well known in these parts to get "stuck" if you don't take all the edges off and make sure there are no burs. So I had more than one local RV builder tell me to take care of that problem before first flight. In that sense, you are not alone.
-------------- Original message --------------
Hi all,
Ron Schreck
RV--8 "Miss Izzy"
<html><body>
<DIV>sort of...</DIV>
<DIV> </DIV>
<DIV>without know how it affected them, the woodruff key is well known in these parts to get "stuck" if you don't take all the edges off and make sure there are no burs. So I had more than one local RV builder tell me to take care of that problem before first flight. In that sense, you are not alone.</DIV>
<DIV> </DIV>
<BLOCKQUOTE style="PADDING-LEFT: 5px; MARGIN-LEFT: 5px; BORDER-LEFT: #1010ff 2px solid">-------------- Original message -------------- <BR>From: "Ron Schreck" <ronschreck(at)alltel.net> <BR><BR>> --> RV-List message posted by: "Ron Schreck" <RONSCHRECK(at)ALLTEL.NET><BR>> <BR>> Hi all, <BR>> <BR>> I had an incident last week that really got my attention. Upon landing, <BR>> when I lowered my RV-8's tail wheel to the runway the tail popped back <BR>> up suddenly and when it came down again the airplane made a sudden <BR>> 20-degree left turn off the runway. My neighbor was watching and he <BR>> said he saw the tail wheel spinning around 360 degrees (on the vertical <BR>> axis) after it bounced the first time. Post-incident autopsy revealed <BR>> that the spring-loaded pin that locks the tail wheel was stuck in the <BR>> retracted position. I removed the pin, polished it and carefully filed <BR>> the pin hole and lubricated the assembly
. It w
wse, C
LessDragProd(at)aol.com Guest
Posted: Thu May 11, 2006 2:01 pm Post subject: Tail Wheel Woes |
| Quote: | From the early RV-3 days, the tail wheel does NOT position itself "in trail".
I have an RV-3 with a locking/full swivel tail wheel. I place the tail
wheel lever in the locked position as I am turning onto the runway. When I have
lined up on the runway, I kick the rudder both directions to confirm the tail
wheel is locked.
Just a little history. Don't know if this helps you.
Jim Ayers
In a message dated 05/11/2006 2:17:37 PM Pacific Daylight Time,
ronschreck(at)alltel.net writes:
Hi all,
(Stuff Cut) I would assume that air
Ron Schreck
RV--8 "Miss Izzy"
bo124rs(at)hotmail.com Guest
Posted: Thu May 11, 2006 2:51 pm Post subject: Tail Wheel Woes |
| Quote: | From: "Ron Schreck" <ronschreck(at)alltel.net>
Ron, Kahuna had the same problem with his tailwheel upon landing at PKB
during the clinic. Same deal, I was with Speedy when we pulled the
tailwheel. A little deburring was done in Smoozer's hanger. Clean it out,
deburr and don't ding Miss Izzy, too nice of a bird.
If you guys don't know Ron, look at the pictures of the "diamond of
diamonds" at vansairforce PKB clinic. Ron is the right hand stinger at the
tailend. He is also shown in Kahuna's second flight video at the same site.
Good luck Ron,
Dana Overall
Richmond, KY i39
RV-7 slider, Imron black, "Black Magic"
O 360 A1A, C/S C2YK-1BF/F7666A4
http://rvflying.tripod.com/id30.html
Dont just search. Find. Check out the new MSN Search!
http://search.msn.click-url.com/go/onm00200636ave/direct/01/
HCRV6(at)comcast.net Guest
Posted: Thu May 11, 2006 9:40 pm Post subject: Tail Wheel Woes |
After some 200+ hours my tail wheel suddenly stopped locking. when I disassembled it I found that the spindle had started to gall at the top and a fine sliver of metal had worked its way into the slot for the locking pin, very effectively jamming the pin in the retracted position. After some careful filing and polishing of the spindle, the pin and the slot, and two tries, I think I have got it working properly again.
I'm certain the original problem was caused by lack of lubrication at the top of the spindle. As was reported several years ago on this list, just shooting grease into the zirk fitting on the housing does not guarantee that grease will get to the top of the spindle where it is really needed. from now on I will disassemble and grease the spindle and locking pin at every 25 hour oil change.
For those tailwheel builders our there I suggest that you disassemble the locking mechanism and carefully smooth all the edges and corners of the locking pin and grease it well before reassembling it.
Harry Crosby
RV-6 N16CX, 209 hours
-------------- Original message ----------------------
Hi all,
Ron Schreck
RV--8 "Miss Izzy"
mstewart(at)iss.net Guest
Posted: Fri May 12, 2006 4:07 am Post subject: Tail Wheel Woes |
Yes and it's the 3rd time in 200 hours I have removed the key, cleaned,
filed, and polished. Something is not right with this design but I cant
put my finger on it. ARGH!
Mike
alexpeterson(at)earthlink Guest
Posted: Fri May 12, 2006 4:26 am Post subject: Tail Wheel Woes |
--> <mstewart(at)iss.net>
key, cleaned, filed, and polished. Something is not right
with this design but I cant put my finger on it. ARGH!
Mike
It would appear that we need a two wheel RV, given the problems with both
kinds of third wheels!
Alex Peterson
RV6-A N66AP 752 hours
Maple Grove, MN
rver273sb(at)aol.com Guest
Posted: Fri May 12, 2006 4:38 am Post subject: Tail Wheel Woes |
Listers, I have 1450 hrs on my vans full swivel t/w. I had the inner sleeve rotate
because the grease zirk was not engaging the sleeve. Other than that. no problems.
Stewart RV-4
rv8ch
Posted: Fri May 12, 2006 5:12 am Post subject: Tail Wheel Woes |
| Quote: | It would appear that we need a two wheel RV, given the problems with both
Good one! I guess designing the 3rd wheel is not the
glamor job of Van's engineering department. Here's
how the meeting of Van and his engineers might have
gone:
Van: "OK, last on the agenda, any volunteers to
design the third wheel?"
<silence - crickets chirping>
Van: "All right, you - new guy - yea, you. Wake up! ..."
Mickey Coggins
http://www.rv8.ch/
#82007 finishing
_________________ Mickey Coggins
http://www.rv8.ch/ |
lors01(at)msn.com Guest
Posted: Fri May 12, 2006 5:34 am Post subject: Tail Wheel Woes |
These tailwheel problems are obviously the result of running the =
incorrect engine in your RVs. The fine mist of Marvel Mystery Oil =
residue from my rotary engines' exhaust constantly bathes my tailwheel =
with just the proper amount of lubricant. It has worked flawlessly for =
1550+ hours with minimal (zero) maintenance. And that oily =
brownish-red streak down the belly just makes the plane faster.
Tracy Crook
13B Rotary powered RV-4 1550+ hours
20B Rotary powered RV-8 - Soon
Sense of humor - over worked
chaztuna(at)adelphia.net Guest
Jim Anglin
Joined: 10 Jan 2006 Posts: 47 Location: Independence, OR (7S5 Airpark)
Posted: Fri May 12, 2006 7:46 am Post subject: Tail Wheel Woes |
I have Van's locking tailwheel and the pin on mine became stuck in the =
retracted position also, requiring some filing and fitting. I noticed =
it when the rudder pedals were not effective turning off the runway. I =
also don't think the grease fitting is effective in getting grease =
throughout the spindle. I take mine loose periodically and lube the =
whole thing by hand.
Jim Anglin
HR II N144HR
DO NOT ARCHIVE
_________________ Jim Anglin
HR II N144HR |
skylor4(at)yahoo.com Guest
Posted: Fri May 12, 2006 8:02 am Post subject: Tail Wheel Woes |
It would appear that third wheel design at Vans' ranks
right up there with baffles and IO-360 induction
snorkels!
Incidently, the induction snorkel kit for forward
induction engines is the biggest joke I've ever
seen...right down to the half assed hand sketches in
the instructions.
DO NOT ARCHIVE!
--- Mickey Coggins <mick-matronics(at)rv8.ch> wrote:
the
gone:
Mickey Coggins
http://www.rv8.ch/
#82007 finishing
browse
Subscriptions page,
FAQ,
Admin.
Posted: Fri May 12, 2006 9:12 am Post subject: Tail Wheel Woes |
For biggest joke, I vote for the supplementary instruction sheet on RV-8 =
fuselage QB kits. It reads (and I'm not making this up):
"Start at the tail and work forward."
I spent more time digging the necessary steps from instruction manual =
than doing them.
Tracy Crook
<skylor4(at)yahoo.com<mailto:skylor4(at)yahoo.com>>
snorkels!
the instructions.
DO NOT ARCHIVE!
--- Mickey Coggins =
Terry Watson
Joined: 09 Jan 2006 Posts: 270 Location: Seattle, WA USA
Posted: Fri May 12, 2006 9:56 am Post subject: Tail Wheel Woes |
You guys are going to be in trouble when Jerry sees this!
Terry
than doing them.
Tracy Crook
snorkels!
the instructions.
DO NOT ARCHIVE!
jsflyrv(at)verizon.net Guest
Posted: Fri May 12, 2006 12:41 pm Post subject: Tail Wheel Woes |
Terry Watson wrote:
Terry
LOL!!! good one Terry, I can't comment on something I don't know
anything about. I don't have a QB or an
RV-8 or an RV with the third wheel in the wrong place nor do I have a
full swivel tailwheel. Sounds like
I should be glad I don't
| Quote: | -> RV-List message posted by: "Tracy Crook" <lors01(at)msn.com>
I don't understand the problem with those instructions sounds perfectly
logical to me. Having built RV-6
number two any instructions sounds good to me. I've said it before I had
100 hours on my airplane before
I got the finnish kit instructions.
| Quote: | I spent more time digging the necessary steps from instruction manual =
than doing them.
Tracy Crook
snorkels!
the instructions.
DO NOT ARCHIVE!
Jerry
don.wentz(at)intel.com Guest
Posted: Fri May 12, 2006 1:34 pm Post subject: Tail Wheel Woes |
I've never had the pin stick in my full swivel in over 700hrs of use,
but like Jim, I take it off and lube it at least twice per year. Never
had to file it or anything, just wipe off the old grease and smear on
some new.
Dw
N790DW RV-6 925hrs
Nic(at)skyhi.flyer.co.uk Guest
Posted: Sat May 13, 2006 3:54 am Post subject: Tail Wheel Woes |
Dan, Thanks for your feedback on the Bell tailwheel (mine has yet to
rrive) - it sounds as though I will need to be vigilant on the maintenance.
In several yeas I have never once had this problem with my Pitts S1, which
can be a handful in strong conditions and is fitted with a Maule TW. I
agree about tailwheel steering awareness - in this case I had a v. strong
crosswind and managed to control the roll out until the rudder became
ineffective, however the crosswind was far too strong for differential
braking without additional power and blew the plane towards the edge of the
runway - and therein lies the problem, as in order to keep her straight (I
had no passenger in the back) the tail lifted and I am sure you know the
scenario. I shutdown, had a cup of tea, and then got a guy to ride in the
back to the hangar, where we stripped the TW and found the problem, and now
all is well.
Anyway, my point is that the Vans tailwheel design or manufacturing should
be improved. In extreme conditions, it can cause pilots severe damage to the
aircraft, if it fails, as it regularly does without special attention. In my
opinion it is not safe (others have obviously had the same problems). I
think you will agree that a pilot that has spent several years building an
RV8, shouldn't have to find out the hard way, that a new tailwheel with zero
hours has a problem which "could" cause the aircraft to end up off the
runway. Rgds, Nic
| Quote: | The problem you saw would have occurred with Doug Bell's tailwheel fork as
well -- and while Doug's tailwheel fork is very nice (I have one), it's not
a cure-all. It has the identical key/shaft design as Van's fork...in fact
you use Van's key with it.
That said, imho all taildragger pilots need to be prepared for the scenario
where they have no tailwheel steering on landing. The plane flies just
fine, and you should have rudder authority down to a speed at which
differential braking is used (yet another reason to keep your brakes in
tip-top shape). This may sound funny, but if the key ever sticks and you
lose steering, my 2 cents is to *take advantage* of that opportunity to
practice handling it -- before you fix it. Maybe not a takeoff/landing if
you're not confident about that, but at least taxi around a bit and get the
feel for using only rudder & brakes. That way you're better prepared if
and
| Quote: | when it bites you. Dan, RV-7 N714D (901 hours)
jrdial(at)hal-pc.org Guest
Posted: Sat May 13, 2006 10:01 am Post subject: Tail Wheel Woes |
I had the problem caused by me not keeping it cleaned
and greased so I now take it apart every 150 hours and service it. I am
not familiar with Doug Bell set up, so would somebody send me his
web-site.
Dick Dial
N89DD
DO NOT ARCHIVE
