Monowheel Brakes
MJKTuck(at)cs.com
PostPosted: Fri Mar 18, 2011 5:09 pm    Post subject: Monowheel Brakes Reply with quote
Hi Folks,
My brake pads are more than 10 years old and I think are probably hard
and shiny - anyway, less effective than they used to be so I think it is
time I replaced them.
Does anyone know the Aircraft Spruce numbers for the pads?
Also, I want to replace the monowheel inner tube as I feel I'm living
on borrowed time (also 10 years old). It has a 90 deg turn on the valve
as I recall. Anyone have the part number for that too?
Martin Tuck
Europa N152MT
Wichita, Kansas
acrojim7534(at)YAHOO.COM
PostPosted: Sat Mar 19, 2011 3:12 am    Post subject: Monowheel Brakes Reply with quote
Martin, the part number is 66-106 for the brake pads...
JimBrown
To: Europa Builders Forum <europa-list(at)matronics.com>
Sent: Fri, March 18, 2011 9:05:51 PM
Subject: Monowheel Brakes
--> Europa-List message posted by: Martin Tuck <MJKTuck(at)cs.com (MJKTuck(at)cs.com)>
Hi Folks,
My brake pads are more than 10 years old and I think are probably hard and shiny - anyway, less effective than they used to be so I think it is time I replaced them.
Also, I want to replace the monowheel inner tube as I feel I'm living on borrowed time (also 10 years old). It has a 90 deg turn on the valve as I recall. Anyone have the part number for that too?
Martin Tuck
Europa N152MT<= nbsp; ================
h&jeuropa
PostPosted: Sat Mar 19, 2011 3:45 am    Post subject: Re: Monowheel Brakes Reply with quote
Martin,
We found the tube only at Wicks Aircraft. P/N for the tube is
TB-MTAT8X6. They also have brake pads, P/N CWB66-106. Rivets for pads available there too.
Jim & Heather
MJKTuck(at)cs.com
PostPosted: Sat Mar 19, 2011 8:38 am    Post subject: Monowheel Brakes Reply with quote
Many thanks!
On 3/19/2011 6:45 AM, h&amp;jeuropa wrote:
Martin,
Jim& Heather
