Extra thickness where cowl top and bottom meet
graeme bird
PostPosted: Sun Mar 20, 2011 10:26 am    Post subject: Extra thickness where cowl top and bottom meet Reply with quote
Whats the best way to handle the extra thickness where the top and bottom cowl over lap and bolt onto the firewall side. The extra thickness looks naff. I was going to bolt through them both but I could remove the lower cowl for an inch or so and bolt through the top or bolt through both by making a slot in the fuselage about an 1/8th deep. Views?
Graeme Bird
kit4 (Wagstaff) TBD
Kit 1 G-UMPY - Mono Classic/XS 912S, Woodcomp G(@)gdbmk.co.uk
neveyre(at)aol.co.uk
PostPosted: Sun Mar 20, 2011 10:47 am    Post subject: Extra thickness where cowl top and bottom meet Reply with quote
Hi Graeme,
If the fuselage is filled and painted, cut away the overlapping part of the lower cowl, if not filled yet, cut a ''window'' into the firewall joggle, tape the cowl with packing tape [ to release] and fit both cowls together, and do a 6 Bid lay up to close off the hole.
Nev.
