rv10flyer(at)verizon.net Guest
Posted: Thu Mar 24, 2011 12:26 pm Post subject: Matco RV-10 Nosewheel Axle replacement write-upMatco RV-10 |
One of the items that was bothering me about the rear tubes was the angle
the stem comes out of the tire. It made for checking the pressure rather
hard, usually I lost 1-2psi just trying to get the gauge in there to check
it. I discovered yesterday that Desser sells a tube for the 15-600/6 tires
that has a stem with a 75 degree angle on it. I ordered a couple as it
bothers me enough to just put in now versus continuing to deal with the
current stem.
http://www.desser.com/store/products/15%7B47%7D600%252d6-%22LEAKGUARD%22-BUTYL-TUBE-(New-Easy-Valve).html
Pascal
