Fox5flyer Guest
Posted: Sat Mar 26, 2011 12:25 pm Post subject: Digital clock/timer |
I'm looking to fill a 2.25" hole in my panel with a useful instrument. One thing that comes to mind is a digital clock/timer of some sort. Anybody have any suggestions based on personal experience?
Deke Morisse
NE Michigan
S5/Soob
dave
Posted: Sat Mar 26, 2011 1:11 pm Post subject: Digital clock/timer |
G meter
Hundreds of Kitfox Movies
Most viewed Kitfox on youtube
Most popular on youtube
Highest rated on youtube |
lcfitt(at)sbcglobal.net Guest
Posted: Sat Mar 26, 2011 1:25 pm Post subject: Digital clock/timer |
Deke,
I did the same, but don't have any ready suggestions. What prompts my note - good to hear your voice.
Lowell
Sent: Saturday, March 26, 2011 1:18 PM
To: Kitfox List (kitfox-list(at)matronics.com)
Subject: Digital clock/timer
Deke Morisse
NE Michigan
S5/Soob
href="http://www.matronics.com/Navigator?Kitfox-List">http://www.matronhref="http://forums.matronics.com">http://forums.matronics.com
clint_bazzill(at)hotmail. Guest
Posted: Sat Mar 26, 2011 1:41 pm Post subject: Digital clock/timer |
The perfect instrument is Flight Data Systems GT-50. Multi function G meter, timer, clock etc etc.
I love it.
Clint
Subject: Re: Digital clock/timer
Date: Sat, 26 Mar 2011 14:16:43 -0700
Deke,
Lowell
Deke Morisse
NE Michigan
S5/Soob
target="_blank">http://www.matronics.com/Navigator?Kitfox-List
Fox5flyer Guest
Posted: Sat Mar 26, 2011 5:08 pm Post subject: Re: Digital clock/timer |
That is what I was looking to hear as it is the instrument I've been looking at, Clint. I just pulled an analog G-meter out, mostly because I was only using it to see how rotten my landings were. I plan to sell it and replace it with something more useful and the G-50 seems like the ideal thing, and will fit the hole.
Deke
[quote="clint_bazzill(at)hotmail."]The perfect instrument is Flight Data Systems GT-50. �Multi function G meter, timer, clock etc etc.
I love it.
Clint
Deke,
I did the same, but don't have any ready suggestions.� What prompts my note - good to hear your voice.
Lowell
I'm looking to fill a 2.25" hole in my panel with a useful instrument.� One thing that comes to mind is a digital clock/timer of some sort.� Anybody have any suggestions based on personal experience?
Deke Morisse
NE Michigan
S5/Soob
[b] |
Fox5flyer Guest
Posted: Sat Mar 26, 2011 5:13 pm Post subject: Re: Digital clock/timer |
Hola, Lowell. Long time... I'm doing my annual and I should be finished about the time the snow melts and my airstrip is dry enough to use. After being down much of the winter it will be nice to get back in the air.
Deke
S5
NE Michigan
[quote="lcfitt(at)sbcglobal.net"]Deke,
Lowell
ltaylor02(at)Chartermi.ne Guest
Posted: Sun Mar 27, 2011 4:38 am Post subject: Digital clock/timer |
You just might get some interesting replies for this one....!
Dick Maddux
Posted: Sun Mar 27, 2011 5:07 am Post subject: Digital clock/timer |
Deke,
I too had that same problem when I had 2 failures of my Northstar fuel flow system. I yanked that gage out and said no more,this is too expensive !
I filled the hole ,I believe,with a MGL combo clock,timer,OAT gage. I looked at so many different gages I am not 100% sure it is MGL but if you are interested I will check.
Anyway it works,and was inexpensive. I wanted the OAT so I can see how hot it is here in FL. I didn't have a need for a "G" meter as I don't do acro with my plane. The timer is great for fuel planning ,etc. It's been in the plane almost a year now and works fine. (matches the other gages too)
Dick Maddux
912 Fox4
Milton,Fl
calvin(at)mlgc.com Guest
Posted: Mon Mar 28, 2011 6:09 am Post subject: Digital clock/timer |
How about an LRI (lift reserve indicator)?
It is easy to make, cheap, and more accurate as a stall indicator than an ASI.
Here is a link.
http://www.mountainflying.com/Pages/articles/alpha_systems_aoa.html
Cal Anderson
