mau11(at)free.fr Guest
Posted: Sun Mar 27, 2011 7:40 am Post subject: Dynon altitude hold |
Hi all,
Does anyone have a Dynon altitude hold feed back on Europa mono?
Michel AUVRAY
l
ploucandco
Posted: Sun Mar 27, 2011 9:52 am Post subject: Re: Dynon altitude hold |
Bonjour Michel,
I have both the pitch and roll SV32 dynon servos in my Europa XS mono connected to a D10A. I don't have the AP74 and typically use the CWS switch on the stick to enable and disable both servos. It is possible to use the menus on the Dynon, but the CWS stich is very easy.
The whole system is really excellent for an extremly low price when you already have a Dynon EFIS (what was my case).
The feature that could be very useful is a pitch autotrim. As soon as you change power settings or you turn steeply, the Dynon EFIS indicates that you need to retrim. Well, this is also typically the case without autopilot, so nothing new
When you are strongly out of trim, the pitch servo is often slipping, so potentially an SV42 servo for the pitch would be preferable. But as you have indication that you need to retrim, this is really not an issue from my perspective and so decided to stay with the SV32.
Also, with the 5.4 EFIS Software version, I saw that the system is slightly hunting at the new altitude when you request a change of altitude and let the system change the altitude for you. As I need to do that via the menu, I almost never do that and prefer to use the CWS switch.
My preferred use model is the following: I am at 1000 feet with the autopilot enabled and I want to go to 2000. I press the CWS switch, climb to my new altitude and depress the CWS. Then no issue at all, the system strongly maintains 2000 feet.
Potentially, with an AP74 or HS34 and the ability to use a button to dial a new altitude, I would use another way to change of altitude and then encounter this hunting issue. But, I also have to admit that I also didn't spend much time to tune up the settings for pitch and I am pretty sure that these are not well tuned.
By the way, if you need, I have a MOD76 kit (altitude hold) from Europa. I didn't use it when the autopilot was installed as it took too much time between order and delivery. Feel free to come back to me if you are interested.
Kind regards, Jacques.
