rv10flyer(at)verizon.net Guest
Posted: Fri Mar 25, 2011 8:40 am Post subject: Matco RV-10 Nosewheel Axle replacement write-up - A must R |
You are so right about all the aftermarket options available in the last
year alone. I can tell you there is a lot more in the skunk works I know may
be out by Osh. I believe if I can help those behind me with better options
so they don’t have to suffer the pain we did, I will. Basically everything
you're doing very well Tim.
As an example, Windscreen and windows is a HUGE option, anyone who doesn't
go the Cee Baileys route is really doing yourself a disfavor! The price is
the same, all the trimming is done for you when it arrives.. That was about
20 hours and numerous scratches from on-and off fitting that future builders
don’t need to endure.
I push http://www.vansaircrafttires.com/categories/RV%252d10/ for a reason,
I make NOTHING on this other than knowing I am sending you to a "one stop
shop" place for everything you need for the RV-10. Yes, I was blessed to
work with them for the windscreen, but in doing so I saw amazing attention
to detail and fair pricing for the work, I believe they could easily charge
more and it would be worth it, as the final product is better. The wingtip
lens are not even worth comparing, there is no comparison between the Vans
one piece and the one you get from Cee Baileys, it arrives fitting or with
minor trimming and is far superior quality.
As Tim said, newer builders will get better, easier and better options, than
anyone before them had available to them.
Pascal
