Low wing?
1rv4
PostPosted: Sat Apr 02, 2011 7:49 am    Post subject: Low wing? Reply with quote
Hi Matt
Another trick to try before you start squeezing ailerons is to cut a V block of dense wood or plastic to the shape of the trailing edge of the ailerons from the plans.Place this block along the trailing edge of the ailerons at various positions and it will give you a very good idea if your ailerons are the same or if they are the least bit distorted. But as everyone has said make sure everything else is trued up first, flaps included.
      Good Luck
      Chris
