dwntzl(at)yahoo.com Guest
Posted: Mon Apr 04, 2011 5:24 pm Post subject: Which battery are you using? |
Listers,
I have been using an SVR Sealed battery for the past 5 or 6 years based an a lister recomendation way back then. First the SVR 14, then the SVR 20, and for the past year or so the SVR 30 (30 amp hr, 350CCA). Even this latest one just barely turns the engine over (O320 with a SkyTec starter), and when it's hot, it is even worse. Fortunately, my engine starts easily and I've only had problems once or twice over these past 550+ hours. However, I've decided to make a change - so my question is. . . What are you using, and, are you happy with it's performance??
Thank you in advance.
David Wentzell - RV6
vanremog(at)aol.com Guest
Posted: Mon Apr 04, 2011 5:37 pm Post subject: Which battery are you using? |
Dave-
Many of us are using the PC680 Odyssey VRLA type batteries with good results. It has quite good CCA but is only a 14Ah battery weighing about 12 lbs IIRC.
-GV (RV-6A N1GV flying 970hrs)
In a message dated 04/04/11 18:25:42 Pacific Daylight Time, dwntzl(at)yahoo.com writes:
| Quote: | .aolmailheader {font-size:8pt; color:black; font-family:Arial} a.aolmailheader:link {color:blue; text-decoration:underline; font-weight:normal} a.aolmailheader:visited {color:magenta; text-decoration:underline; font-weight:normal} a.aolmailheader:active {color:blue; text-decoration:underline; font-weight:normal} a.aolmailheader:hover {color:blue; text-decoration:underline; font-weight:normal}
Listers,
robin(at)PaintTheWeb.com Guest
Posted: Mon Apr 04, 2011 5:46 pm Post subject: Which battery are you using? |
I think there was a group buy for Odyssey Batteries posted on the RV list recently referencing a VAF posting.
Here is something from a VAF posting. I have no knowledge of the company or who posted the pricing. Just passing it along.
Bohannon Battery in Florida: http://www.bohannonbattery.com/html/odyssey.html
Odyssey PC680 $115.41 and free shipping. My experience was positive overall with a quick replies to e-mails.
Robin
From: owner-rv-list-server(at)matronics.com (owner-rv-list-server(at)matronics.com) [mailto:owner-rv-list-server(at)matronics.com (owner-rv-list-server(at)matronics.com)] On Behalf Of d wntzl
Sent: Monday, April 04, 2011 6:17 PM
To: rv-list(at)matronics.com (rv-list(at)matronics.com)
Subject: RV-List: Re: Which battery are you using?
Listers,
David Wentzell - RV6 RV-List Email Forum -[/b]_-= Use the Matronics List Features Navigator to browse[/quote][/b][/quote] Day Browse, Chat, FAQ,[/b]w.matronics.com/Navigator?RV-List">http://www.matronics.com/Navigator?RV-Li
=====================< - MATRONICS WEB FORUMS -[/b][/quote] m">http://forums.matronics.com[/b][/quote] -Matt Dralle, List A; http://www.matronics.com/contribution[/b][/quote] =======================[/b] [/quote]
Checked by AVG - www.avg.com
Version:body> [quote][b]
Ed Anderson
Posted: Mon Apr 04, 2011 6:06 pm Post subject: Which battery are you using? |
David, I have used the Odyssey PC680 in my RV-6A for the last 10 years and am very happy with price and performance.
Ed
Edward L. Anderson
Anderson Electronic Enterprises LLC
305 Reefton Road
Weddington, NC 28104
http://www.andersonee.com
http://www.eicommander.com
Sent: Monday, April 04, 2011 9:16 PM
Subject: Re: Which battery are you using?
Listers,
href="http://www.matronics.com/Navigator?RV-List">http://www.matronics.com/Navigator?RV-List
_________________ Ed Anderson
Rv-6A N494BW Rotary Powered
Matthews, NC
eanderson@carolina.rr.com |
Kellym
Posted: Mon Apr 04, 2011 6:54 pm Post subject: Which battery are you using? |
Your bigger issue is the Skytec starter. If it is one of the original PM
series, it has a very high current draw to over come the compression
stroke. The later NL series (inline) have much less draw, as do other
brands like B&C or Kelly E series.
The PM series need a good battery, excellent battery cables, excellent
connections and grounds to work well. Be sure all your ground cables
from engine to airframe and airframe to battery are top notch.
On 4/4/2011 6:16 PM, d wntzl wrote:
Listers,
KCHD |
JohnInReno
Posted: Tue Apr 05, 2011 6:53 am Post subject: Which battery are you using? |
Check the voltage at the starter. My similar problem turned out to be the 'bendix' on the starter.
John Morgensen
RV4 - purchased flying
RV9A - soon
On 4/4/2011 6:16 PM, d wntzl wrote: [quote]
Listers,
_________________ John Morgensen
RV-9A - Born on July 3, 2013
RV4 - for sale |
bjudge(at)gmail.com Guest
Posted: Tue Apr 05, 2011 7:15 am Post subject: Which battery are you using? |
I've been using a single PC625 to crank my IO-360 and haven't had any problems in 600 hrs. With dual electronic ignition I'm electric dependent and so I have a second PC625 in the rear position that is the emergency battery. Every 2 years I replace the E battery with a new one and move the old E battery to the front to crank the engine. The cranking battery sits where the fuel pump normally goes in an RV-8.
The reliability of a battery changes if you use it to crank your engine. My understanding is that they have different curves for the reliability of batteries that crank as a part of regular service and batteries that don't crank. This difference is supposed to be substantial so if you can avoid cranking with your back up battery you should.
When I did the initial design I made provisions to crank off both batteries but I've never had to do that. With the arrangement I've got the cranking battery is never older than 4 years and the E battery is never older than 2. The Odyssey batteries are pretty amazing, the PC625 looks tiny but cranks my skytec just fine. Right now the PC625 is about $100 so that's pretty cheap in airplane terms every 2 years, even still it's usually the most expensive thing in the annuals when I do replace it!
VR,
Bill
RV-8, N84WJ 600 hrs.
On Mon, Apr 4, 2011 at 11:59 PM, RV-List Digest Server <rv-list(at)matronics.com (rv-list(at)matronics.com)> wrote:
[quote]*
Today's complete RV-List Digest can also be found in either of the
of the RV-List Digest and can be viewed with a generic text editor
HTML Version:
http://www.matronics.com/digest/digestview.php?Style=82701&View=html&Chapter=2011-04-04&Archive=RV
Text Version:
http://www.matronics.com/digest/digestview.php?Style=82701&View=txt&Chapter=2011-04-04&Archive=RV
RV-List Digest Archive
Total Messages Posted Mon 04/04/11: 5
Today's Message Index:
1. 06:24 PM - Re: Which battery are you using? (d wntzl)
2. 06:37 PM - Re: Re: Which battery are you using? (vanremog)
3. 06:46 PM - Re: Re: Which battery are you using? (Robin Marks)
4. 07:06 PM - Re: Re: Which battery are you using? (Ed Anderson)
5. 07:54 PM - Re: Re: Which battery are you using? (Kelly McMullen)
Time: 06:24:58 PM PST US
From: d wntzl <dwntzl(at)yahoo.com (dwntzl(at)yahoo.com)>
Listers,
-- I have been using an SVR Sealed battery for the past 5 or 6 years ba
sed an a lister recomendation way back then. First the SVR 14,- then the
SVR 20, and for the past year or so the SVR 30 (30 amp hr, 350CCA).- Even
ter), and when it's hot, it is even worse.- Fortunately, my engine starts
-- Thank you in advance.
----- David Wentzell- -- RV6
Time: 06:37:36 PM PST US
From: vanremog <vanremog(at)aol.com (vanremog(at)aol.com)>
Subject: Re: Re: Which battery are you using?
Dave-
In a message dated 04/04/11 18:25:42 Pacific Daylight Time, dwntzl(at)yahoo.com (dwntzl(at)yahoo.com) writes:
Listers,
it's performance??
Time: 06:46:16 PM PST US
Subject: RE: Re: Which battery are you using?
Bohannon *Battery* in Florida:
Robin
*From:* owner-rv-list-server(at)matronics.com (owner-rv-list-server(at)matronics.com) [mailto:
owner-rv-list-server(at)matronics.com (owner-rv-list-server(at)matronics.com)] *On Behalf Of *d wntzl
*Sent:* Monday, April 04, 2011 6:17 PM
*To:* rv-list(at)matronics.com (rv-list(at)matronics.com)
*Subject:* Re: Which battery are you using?
Listers,
________________________________ Message 4 _____________________________________
Time: 07:06:12 PM PST US
From: "Ed Anderson" <eanderson(at)carolina.rr.com (eanderson(at)carolina.rr.com)>
Ed
Edward L. Anderson
305 Reefton Road
Listers,
it's performance??
________________________________ Message 5 _____________________________________
Time: 07:54:05 PM PST US
From: Kelly McMullen <kellym(at)aviating.com (kellym(at)aviating.com)>
> Listers,
get="_blank">http://www.matronics.com/Navigator?RV-List
le, List Admin.
bobbyhester(at)newwavecom Guest
Posted: Tue Apr 05, 2011 8:17 am Post subject: Which battery are you using? |
Mine is 5 yrs old and 460 hrs. Still cranks fine.
Sent from my Verizon iPhone
On Apr 5, 2011, at 10:12 AM, Bill Judge <bjudge(at)gmail.com (bjudge(at)gmail.com)> wrote:
[quote]I've been using a single PC625 to crank my IO-360 and haven't had any problems in 600 hrs. With dual electronic ignition I'm electric dependent and so I have a second PC625 in the rear position that is the emergency battery. Every 2 years I replace the E battery with a new one and move the old E battery to the front to crank the engine. The cranking battery sits where the fuel pump normally goes in an RV-8.
VR,
Bill
On Mon, Apr 4, 2011 at 11:59 PM, RV-List Digest Server <[url=mailto:rv-list(at)matronics.com]rv-list(at)matronics.com (rv-list(at)matronics.com)[/url]> wrote:
| Quote: | *
HTML Version:
[url=http://www.matronics.com/digest/digestview.php?Style=82701&View=html&Chapter 11-04-04&Archive=RV]http://www.matronics.com/digest/digestview.php?Style=82701&View=html&Chapter 11-04-04&Archive=RV[/url]
Text Version:
[url=http://www.matronics.com/digest/digestview.php?Style=82701&View=txt&Chapter 11-04-04&Archive=RV]http://www.matronics.com/digest/digestview.php?Style=82701&View=txt&Chapter 11-04-04&Archive=RV[/url]
From: d wntzl <[url=mailto:dwntzl(at)yahoo.com]dwntzl(at)yahoo.com (dwntzl(at)yahoo.com)[/url]>
Listers,
From: vanremog <[url=mailto:vanremog(at)aol.com]vanremog(at)aol.com (vanremog(at)aol.com)[/url]>
Dave-
In a message dated 04/04/11 18:25:42 Pacific Daylight Time, [url=mailto:dwntzl(at)yahoo.com]dwntzl(at)yahoo.com (dwntzl(at)yahoo.com)[/url] writes:
Listers,
it's performance??
From: Robin Marks <robin(at)PaintTheWeb.com (robin(at)PaintTheWeb.com)>
Robin
*From:* [url=mailto:owner-rv-list-server(at)matronics.com]owner-rv-list-server(at)matronics.com (owner-rv-list-server(at)matronics.com)[/url] [mailto:
[url=mailto:owner-rv-list-server(at)matronics.com]owner-rv-list-server(at)matronics.com (owner-rv-list-server(at)matronics.com)[/url]] *On Behalf Of *d wntzl
*To:* [url=mailto:rv-list(at)matronics.com]rv-list(at)matronics.com (rv-list(at)matronics.com)[/url]
Listers,
From: "Ed Anderson" <[url=mailto:eanderson(at)carolina.rr.com]eanderson(at)carolina.rr.com (eanderson(at)carolina.rr.com)[/url]>
Ed
Edward L. Anderson
305 Reefton Road
Listers,
it's performance??
From: Kelly McMullen <[url=mailto:kellym(at)aviating.com]kellym(at)aviating.com (kellym(at)aviating.com)[/url]>
> Listers,
le, List Admin.
