Air struts
bakerocb
PostPosted: Tue Apr 12, 2011 1:43 pm    Post subject: Air struts Reply with quote
4/12/2011
Hello Al, You wrote:
1) ".... how to dig up past posts."
Click on the navigator web page found at the bottom of each matronics list -- see here:
Click on:
http://www.matronics.com/search
scroll to Select Archive: KIS
Type your Search String of interest in the box and click on Begin Search.
2) "Whats a good place to buy them .....?
I order mine by phone from Guden. See here:
http://www.guden.com/control-GS5-dup.aspx
3) "....what type and size should I get?"
The type I use is the standard black ones like these:
http://www.guden.com/ItemDisplay/ItemDisplay.aspx?wpn=GS5&mtf=StandardGS.txt&cmf=-%20please%20select%20-
For length you have to measure your own desired door opening and closing situation. Some Cruiser builders favored the 35 PSI type and used two per door.
Good luck,
'OC' Baker Says: "The best investment we can make is the time and effort to gather and understand knowledge."
To: kisbuilders (kis-list(at)matronics.com)
Sent: Tuesday, April 12, 2011 1:27 PM
Subject: Air struts
My air struts for the Cruiser doors got lost in the move to Florida. I know that this was discussed before but I must confess to my ignorance of how to dig up past posts. Whats a good place to buy them and
Al
href="http://www.matronics.com/Navigator?KIS-List">http://www.matronics.com/Navigator?KIS-List
sstearns2(at)yahoo.com
PostPosted: Tue Apr 12, 2011 10:48 pm    Post subject: Air struts Reply with quote
McMaster Carr has a good selection.� If you get a strut with too high a force it will distort the door when closed. I'd look for one about 18" long and about 30 pounds of force.� I'd buy one and mess with it and see if the force and length workout.�
Scott
--- On Tue, 4/12/11, ALFRED ROSA <fredorosa(at)gmail.com> wrote:
Subject: Air struts
To: "kisbuilders" <kis-list(at)matronics.com>
Date: Tuesday, April 12, 2011, 10:27 AM
Al
=nofollow target=_blank>http://www.matronics.com/Navigator?KIS-List
kcruiser1947(at)yahoo.com
PostPosted: Wed Apr 13, 2011 2:45 am    Post subject: Air struts Reply with quote
Hi Al
When building my Cruiser I used the supplied struts mounted at the rear of the door rather than the front as called for. I did not want them in my field of view when flying. After having the doors blow closed a few times I replaced them with 60 pound units and have not a blow down in 8 years.
Bob Anderson
Cruiser N949Y
Subject: Air struts
Date: Tuesday, April 12, 2011, 12:27 PM
Al
et=_blank rel=nofollow>http://www.matronics.com/Navigator?KIS-List
=nofollow>http://forums.matronics.com
blank rel=nofollow>http://www.matronics.com/contribution
wschertz(at)comcast.net
PostPosted: Sat Apr 23, 2011 2:23 pm    Post subject: Air struts Reply with quote
I put mine at the rear, and am happy with the location. 60# if I recall correctly.
Bill Schertz
KIS Cruiser #4045
N343BS
Phase one testing Completed
Sent: Saturday, April 23, 2011 10:14 AM
Subject: Air struts
Now that the hinge question has been resolved, I would like to do the same with the air struts. I reinforced the front part of the door thinking that was where I would place the strut but now am questioning that placement
as possibly being an intrusion for the pilot and copilot. Have people found that a rear placement of the struts is
a better way to go?
Also, using only one strut per door, what would be the recommended pressure rating for a Cruiser door.
I'm guessing about 40 lbs.
Al
jerzy_krasinski(at)sbcglo
PostPosted: Sat Apr 23, 2011 6:02 pm    Post subject: Air struts Reply with quote
To: kis-list(at)matronics.com
Sent: Sat, April 23, 2011 5:12:00 PM
Subject: Re: Air struts
Bill Schertz
KIS Cruiser #4045
N343BS
Subject: Air struts
a better way to go?
Al
href="http://www.matronics.com/Navigator?KIS-List">http://www.matronics.com/Navigator?KIS-Listhref="http://forums.matronics.com">http://forums.matronics.com
[b]http://www.matronics.rums.matronics.com/" target=_blank rel=nofollow>http://forums.matronics-> [b]
