Gluing Tip
Fergus Kyle
PostPosted: Tue Apr 12, 2011 9:39 am    Post subject: Gluing Tip Reply with quote
I must share this slowly-realised opinion, since I use it regularly. First, I am in my 14th year of construction – for many reasons, one of which is sloth.
However, Bob Nuckols suggested “Shoo Goo”, also known as E6000 I believe – and which is locally available at the Dollar Store.
It is clear, colourless and an alcohol-based adhesive which squeezes out (not really liquid) and sets fairly quickly. By the time the day is up, it’s pretty hardened but it continues until really stiff. It does not transmit electricity, but CAN be pried out/off with a blade if necessary. It hardens in the tube after about a year.
I used it to fix cable runs when an epoxied base was not feasible, but then I needed something running a bit thinner. I mixed an equal amount of Toluol [acetone don’t do it )into a small plastic container (Kodak 35mm) with an equal dollop of Shoo Goo and shook and stirred it until reduced in viscosity. Magic.
I may now apply the thinner adhesive onto exposed wiring, and adjust the thickness progressively (if necessary) with a bamboo stick, and in two days it’s hard as nails and really tenacious. When the ‘rubber nipples” don’t completely seal off the air, thinned Shoo Goo does it nicely – and easily. I have tested it after 5 years and found it still as good as ever.
Anyway, it’s worth the try.......
Ferg [quote][b]
grahamsingleton(at)btinte
PostPosted: Tue Apr 12, 2011 2:39 pm    Post subject: Gluing Tip Reply with quote
Fergus
don't suppose you know if it exists our side of the pond do you? No doubt someone thought a different name would be used. Not helpful to we users
Graham
To: 5EUROPALIST <europa-list(at)matronics.com>
Sent: Tuesday, 12 April, 2011 18:34:28
Subject: Gluing Tip
Gluing Tip
However, Bob Nuckols suggested “Shoo Goo�, also known as E6000 I believe – and which is locally available at the Dollar Store.
I may now apply the thinner adhesive onto exposed wiring, and adjust the thickness progressively (if necessary) with a bamboo stick, and in two days it’s hard as nails and really tenacious. When the ‘rubber nipples� don’t completely seal off the air, thinned Shoo Goo does it nicely – and easily. I have tested it after 5 years and found it still as good as ever.
Ferg [quote]http://www.matronics.com/Navigator?Europa-Listllow" target="_blank" href="http://www.matronics.com/contribution">http========================
Fergus Kyle
PostPosted: Tue Apr 12, 2011 7:07 pm    Post subject: Gluing tip Reply with quote
Grahame,
Sorry, can’t answer on the forum because it always refuses my log in, but:
My understanding is that E6000 is an industry designator (must look it up) and so p’raps it can be googled into submission.
Trust you both in good order.....
Ferg
PostPosted: Tue Apr 12, 2011 10:53 pm    Post subject: Gluing tip Reply with quote
we're fine thanks Ferg, Joan just had two weeks in Israel & Jordan, she went to see Petra. I spent some time taxying the Long EZ at the farm strip, readyu for jumping through the documents hoop then de rig, off to a hard runway and test fly.
How are you and Jenny?
Graham
Sent: Wednesday, 13 April, 2011 4:04:07
Subject: Gluing tip
Gluing tip
Grahame,
Ferg
http://www.matronics.com/Navigator?Eurank" href="http://forums.matronics.com">http://forums.matronics.com rel="nofollow" target="_blank" href="http://www.matronics.com/contri===
rowlandcarson(at)gmail.co
PostPosted: Tue Apr 12, 2011 11:44 pm    Post subject: Gluing Tip Reply with quote
Graham - there is stuff called Shoe Goo available on Amazon UK at:
http://www.amazon.co.uk/Shoe-Goo-Original-Formula-Colours/dp/B0010YTLUU/ref=pd_sim_sg_1
and the description seems to match what Fergus described.
Repair Products UK also have E6000 in a different packaging to the Shoe Goo on their website at a slightly higher price than Amazon:
http://www.repairproducts.co.uk/page35.htm
As ever, Google is your friend!
Hope this helps.
Rowland
(currently enduring the attentions of builders - house not aeroplane - for a serious bit of re-modelling)
| pictures: http://picasaweb.google.com/rowlandcarson
Ivor Phillips
PostPosted: Tue Apr 12, 2011 11:57 pm    Post subject: Gluing Tip Reply with quote
Hi Graham
I brought some shoo goo from a English supplier a couple of years ago on EBay, so it should be available
here if you look,
regards
Ivor
On 12 April 2011 23:35, GRAHAM SINGLETON <grahamsingleton(at)btinternet.com (grahamsingleton(at)btinternet.com)> wrote:
[quote] Fergus
Graham
From: Fergus Kyle <VE3LVO(at)rac.ca (VE3LVO(at)rac.ca)>
To: 5EUROPALIST <europa-list(at)matronics.com (europa-list(at)matronics.com)>
Subject: Europa-List: Gluing Tip
Ferg
arget="_blank">http://www.matronics.com/Navigator?Europa-List
PostPosted: Wed Apr 13, 2011 12:02 am    Post subject: Gluing Tip Reply with quote
Thanks Rowland,
must try and stop avoiding google!
Graham
Sent: Wednesday, 13 April, 2011 8:39:51
Subject: Re: Gluing Tip
--> Europa-List message posted by: Rowland Carson <rowlandcarson(at)gmail.com (rowlandcarson(at)gmail.com)>
Hope this helps.
Rowland
| <rowlandcarson(at)gmail.com (rowlandcarson(at)gmail.com)> http://www.rowlandcarson.org.uk
| pictures: http://picasaweb.google.com/rowland href="http://www.matronics.com/Navigator?Europa-List" target="_blank">p; -Matt Dralle, Libution" =======
