Posted: Sun Apr 17, 2011 6:20 am Post subject: FS: Sikaflex 295UV system for bonding RV-10 windows |
greghale
Joined: 10 Jan 2007 Posts: 91 Location: Tulsa, Oklahoma
Posted: Sun Apr 17, 2011 11:50 am Post subject: Re: FS: Sikaflex 295UV system for bonding RV-10 windows |
Don't know what your question was, but if you are thinking about using the Sikaflex system for bonding the windows, you can go to my web page link of how I replaced a windshield using this system. I can highly recommend it for windshield replacement
http://www.nwacaptain.com/windshield.html
It is very easy to clean up by using mineral spirits. Plenty of time to place and adjust the windshield position.
Greg...
_________________ Greg Hale rv10 -- N210KH
www.nwacaptain.com |
Posted: Sun Apr 17, 2011 12:43 pm Post subject: FS: Sikaflex 295UV system for bonding RV-10 windows |
I used this system to install my windows on my RV-10. New from Jamestown Distrubters costs over $113 plus shipping. I have one new unopened tube of the 295 UV adhesive, and well over 1/2 can of the 209D primer and Aktivator. Primer expires in August 2011, Aktivator in September 2011. This is enough to bond in a full set of RV-10 windows.
$75 plus free shipping via FedEx Ground.
-Mike Kraus
[img]cid:0ED27714-14F4-4CB0-9382-74B6219AC025[/img]
Kelly McMullen
Posted: Sun Apr 17, 2011 12:59 pm Post subject: FS: Sikaflex 295UV system for bonding RV-10 windows |
Wasn't there some concern whether Sikaflex provided as strong a bond as
Weld-on?
On Sun, Apr 17, 2011 at 12:50 PM, greghale <ghale5224(at)aol.com> wrote:
A&P/IA, EAA Tech Counselor
KCHD |
rv10flyer
Posted: Sun Apr 17, 2011 4:40 pm Post subject: Re: FS: Sikaflex 295UV system for bonding RV-10 windows |
I also have a partial tube of Weld-On 45 and some mixing tubes an RV-10 builder can have for shipping along with borrowing the gun. I want the $102 gun back when finished. Bond strength is 2000 vs 2200 psi for Weld On 10 and the viscosity makes it much easier to fill gaps and almost no runs/clean up afterwards. I don't believe the 200 psi difference will cause me any problems. I tested plexiglass/aluminum/fiberglass samples and it holds better than West epoxy on all three. You need two 13.5 oz cartridges(approx $35/ea) and you will have a least 1/2 tube leftover. Costs are just slightly more than Weld On 10 since you don't have to buy the gun. Get your cartridges/mixing tubes from The Engineer Guy in Atlanta.
_________________ Wayne G. |
