		kevann(at)gotsky.com Guest
				 Posted: Sat Apr 16, 2011 12:22 pm    Post subject: Jabiru vs. Rotax |
				You are comparing a Jabiru to the turbocharged Rotax, which is more of an
 "apples to oranges" comparison. Better to compare with the 912 and 912s.
 And I think a 914 is close to 30,000 USD. The Jab is going to use far more
 fuel than a Rotax. I find that on average the 914 in my Monowheel is using 5
 GPH. The cost of fuel is going to go up and up.
 I am wondering what a Jab 6 cyl is using per hour?
 Kevin
		AirEupora
				 Posted: Sun Apr 17, 2011 9:41 am    Post subject: Re: Jabiru vs. Rotax |
				You are right Kevin.  Trying to compare a Jabiru to a Rotax 912 or 914 is like comparing Apples and Oranges.  Both taste good.
 The Jabiru will use a little over one gallon more per hour so it will cost me $5.00 more an hour to operate.  If I get to fly 100 hour this coming year it will cost me $500.00 dollars this year over your cost for fuel.  I can still divide that into the initial cost firewall forward.
 I looked on the web pages today and Rotax 912ULS is 21K plus the cost of firewall forward vs. 18K for everything on the Jabiru.
 Rick Stockton
				 Posted: Sun Apr 17, 2011 11:21 am    Post subject: Jabiru vs. Rotax |
				Rick
 there's a lot of good experience out there for you to benefit from. (I don't have much)
 I recommend a good engine monitor with 6 EGTs and 6 CHTs, Mixture distribution is tricky and important.
 Graham
 Sent: Sunday, 17 April, 2011 18:41:04
 Subject: Re: Jabiru vs. Rotax
 --> Europa-List message posted  by: "AirEupora" <AirEupora(at)sbcglobal.net (AirEupora(at)sbcglobal.net)>
 Rick Stockton
 http://forums.matronics.com/viewtopic.php?p=337229#337========================http://www.matronics.com/Navigator?Eurp;  -->
				 Posted: Sun Apr 17, 2011 5:53 pm    Post subject: Jabiru vs. Rotax |
				 	  | Quote: | 	 		   The Jabiru will use a little over one gallon more per hour so it
 Rick,
 	To anyone with or contemplating a Jab for their Europa, I can't think
 of a better resource than archived europa-list posts by John Lawton.
 As I recall, he's posted better performance figures than Bud mentions.
 John's been to Jabiru school and has a Rotax maintenance certification
 as well inasmuch as he regularly flys a motorglider w/ a Rotax in
 addition to his Jabbed Europa trigear.
 	He's also very generous with his time to discus issues and his
 experiences w/ both engines...and quite satisfied w/ his Europa
 installation...I believe his engine has mechanical lifters. I was very
 interested in the Jab (with a fairly complete FWF kit) before the
 demise of Suncoast Aviation.
 	As some of you know, I've proceeded to install a 140 hp MPEFI'd Sube
 variant I bought from RAM Performance Ltd which comes w/ a PSRU from
 N. Zealand, Airtex fuel pump, and a plug-n-play ECU. Cost was  $16.5k
 USD. Spent almost a year designing and fabricating mounting frame,
 cooling & exhaust systems, cowls, remote oil filter/cooler and adding
 sensors for a compatible EMS. The proof will be in the pudding, but I
 hope to join Glenn Crowder who regularly flies his 125 hp carburated
 Sube powered Classic out of his home field at 5000' ASL in Colorado.
 	Stay tuned,
 	Fred
 	A194
		tonyrenshaw268(at)gmail.c Guest
				 Posted: Sun Apr 17, 2011 7:14 pm    Post subject: Jabiru vs. Rotax |
				Hey Graham,
 Why 6 EGTs and CHTs??
 (Hope this finds you and Joan well.)
 Reg
 Tony Renshaw
 On 18/04/2011, at 5:17 AM, GRAHAM SINGLETON <grahamsingleton(at)btinternet.com (grahamsingleton(at)btinternet.com)> wrote:
 [quote]Rick
 Graham
 From: AirEupora <AirEupora(at)sbcglobal.net (AirEupora(at)sbcglobal.net)>
 To: [url=mailto:europa-list(at)matronics.com]europa-list(at)matronics.com (europa-list(at)matronics.com)[/url]
 Subject: Europa-List: Re: Jabiru vs. Rotax
 --> Europa-List message posted  by: "AirEupora" <[url=mailto:AirEupora(at)sbcglobal.net]AirEupora(at)sbcglobal.net (AirEupora(at)sbcglobal.net)[/url]>
 Rick Stockton
 http://forums.matronics.com/viewtopic.php?p=337229#337========================http://www.matronics.com/Navigator?Eurp;  --> [/url]
 [url=http://www.matronics.com/contribution]
				 Posted: Mon Apr 18, 2011 5:40 am    Post subject: Jabiru vs. Rotax |
				On 04/16/2011 10:18 PM, Kevin Klinefelter wrote:
  an "apples to oranges" comparison. Better to compare with the 912 and 912s.
  more fuel than a Rotax. I find that on average the 914 in my Monowheel
  is using 5 GPH.
 I fly my 914, on a heavy hi-top tri-gear, is using about 16 l/h (about 4
 GPH) for cruising at 120 knots.
 Frans
				 Posted: Mon Apr 18, 2011 5:55 am    Post subject: Jabiru vs. Rotax |
				On 04/17/2011 07:41 PM, AirEupora wrote:
 Has the Jab a turbo?
  	  | Quote: | 	 		   The Jabiru will use a little over one gallon more per hour so it will cost me $5.00 more an hour to operate.
 Make it two gallon per hour. That's 10 dollar per hour. And not to
 mention that with a turbo you will be able to fly higher and benefit
 from a higher true airspeed, further reducing the fuel required for a trip.
 Lower fuel consumption means not only cheaper in operations, but also
 the ability to fly longer legs without refueling, or just a saving in
 fuel weight if you just fill her up for a certain time of flying.
  	  | Quote: | 	 		    If I get to fly 100 hour this coming year it will cost me $500.00 dollars this year over your cost for fuel.
 That's really short term calculating. Let's say the airplane plus its
 engine will see a service life of 1500 hours. Then the jab has consumed
 $15000 more than the Rotax (ignoring the fact that the fuel prices will
 go up). Indeed over the service life of the airplane even a 914 with
 turbo is cheaper than a jab. Not to mention the selling price which is
 clearly higher for a 914 than for a jabiru, if you ever choose to sell
 your airplane.
 That was about money. Now think about performance. Or maybe you plan to
 fly only close to the sea level and the higher altitude performance
 hasn't a significant meaning to you.
 You liked to compare against a 914. A 912 is significantly more
 affordable and consumes about the same amount of fuel as a 914. With a
 912 you actually gain a lot of money over the service life compared to a
 Jabiru.
 Just some thoughts. (I don't care what you install in your airplane, but
 I hope you are seeing the whole picture. It would be a shame if the
 project you invested so much of your time in is going to disappoint to.
 Apparently quite some people got very frustrated with their Jabiru, and
 some even converted to a Rotax 914 and wasted the money of their Jab.
 Now let's do the calculation again...)
 Frans
		AirEupora
				 Posted: Mon Apr 18, 2011 6:23 am    Post subject: Re: Jabiru vs. Rotax |
				Just after I receive the kit I started looking at looking at engines.  I had just finished building a plane with an engine that was to big for the plane.  I wanted only to build accordance with the manufactures recommendations.  The original Eurpora had an 80HP Rotax, but I think all pilot's are like Tim Allen, "MORE POWER"!  I have a speed sheet of all the numbers.  TBO, MPG, HP, Torque, speed, price, two blade, three blade, constant speed, ground adjustable.  I used this forum and read all the remarks.  I drove to San Diego and looked at a Subaru installation.  That scared me.  I had just gone through putting a bigger engine on an airframe and I wanted firewall forward no changes.  I looked at 120 vs. 115 HP then the prices.  I read about the problems so I knew going in I would need a good EFIS system to monitor the engine.  I choose the MGL Voyager.  I can monitor the six cylinders and record the flight information during testing.  I knew that Jabiru had made a lot of changes to the engine from when Graham had tried it.  There were larger fins now, hydraulic lifters and a couple of things that help.  Again, PRICE.  One thing I liked about the Jabiru was the KISS principle.  I get to fly my plane for forty hours.  Surely, I can figure out my problems during that time frame.  I will be flying during the hottest time here in California so I have to make it right quickly.  Hopefully, I make to OSH this year.  I’m looking forward to see a lot of you there.
		gcrowder2
  Joined: 09 Jan 2006 Posts: 136 Location: Golden, Colorado USA
				 Posted: Mon Apr 18, 2011 7:05 am    Post subject: Jabiru vs. Rotax |
				Just gitterdun buddy - you're in for a treat!  6 yrs down the road and it still runs like a raped ape!  No regrets except for getting the cooling
  system to work but you have handled that nicely I believe.
        Glenn
  > From: fklein(at)orcasonline.com
 [quote] To: europa-list(at)matronics.com
  Subject: Re: Re: Jabiru vs. Rotax
  Date: Sun, 17 Apr 2011 18:49:06 -0700
  --> Europa-List message posted by: Fred Klein <fklein(at)orcasonline.com>
  Rick,
  Stay tuned,
				 Posted: Mon Apr 18, 2011 3:11 pm    Post subject: Jabiru vs. Rotax |
				Can't argue with your logic Frans. You are right again.
 Graham
 Sent: Monday, 18 April, 2011 14:53:24
 --> Europa-List message posted by: Frans Veldman <frans(at)privatepilots.nl (frans(at)privatepilots.nl)>
  	  | Quote: | 	 		   --> Europa-List message posted by: "AirEupora" <AirEupora(at)sbcglobal.net (AirEupora(at)sbcglobal.net)>
 your airplane.
 Jabiru.
 Now let's do the ca href="http://www.matronics.com/Navigator?Europa-List" target="_blank">p;                 -Matt Dralle, Libution" =======
				 Posted: Mon Apr 18, 2011 5:11 pm    Post subject: Jabiru vs. Rotax |
				" Hopefully, I make to OSH this year.  Iâ?Tm looking forward to see a lot
 of you there."
 I hope to make it to OSH this year too... Hope to see you there with your
 new plane!
 Kevin
