tonyrenshaw268(at)gmail.c Guest
Posted: Fri Apr 22, 2011 10:11 am Post subject: Wing pin mod through flap closeout |
Gidday,
I am pondering this compulsory task, and would like to know if anyone has used this method over the one through the wing skin? If so, would you do it that way again, and have any specific advice? In blind ignorance, it seems better to me. Thanks.
Reg
Tony Renshaw
Sydney Australia
philipgeorge347(at)hotmai Guest
Posted: Fri Apr 22, 2011 11:11 am Post subject: Wing pin mod through flap closeout |
Tony i did the wing pin mod thru the close out and infact had the LAA incorperate my method at the back of the instruction sheets having first had Andy Draper come around to inspect it . Saves a whole lot of filling and refinishing ect . No paint is required and no visible signs left . Will be off line for the next three weeks visiting mother in law in Philippines.
regards.
Philip George. G-EORJ mono
| Quote: | Subject: Wing pin mod through flap closeout
Date: Sat, 23 Apr 2011 04:07:34 +1000
--> Europa-List message posted by: Tony Renshaw <tonyrenshaw268(at)gmail.com>
Gidday,
Reg
Tony Renshaw
Sydney Australia
fklein(at)orcasonline.com Guest
Posted: Fri Apr 22, 2011 11:37 am Post subject: Wing pin mod through flap closeout |
On Apr 22, 2011, at 11:07 AM, Tony Renshaw wrote:
Gidday,
Tony...what do you mean by "this method"?...a ref. to the build manual
instructions might be helpful.
Fred
neveyre(at)aol.co.uk Guest
Posted: Fri Apr 22, 2011 12:24 pm Post subject: Wing pin mod through flap closeout |
Hi Tony,
Go through the closeout, best way by far.
Decide at the same time to do the 1370lb Mod [ if you haven't done that already] as the pin is different, and if you retrofit the 1370 you will have to dig out thepin and nut and redo it ! Tip.... cut out the nyloc ring from the nut, so you can wind it on with a screwdriver pushing on the flats, and only need to crank it the last 1/4 turn with a spanner [ wrench], then ''pot'' it with flox and a couple of plies of Bid before you replace the foam..... saves an awful lot of f*&*$$+**&*
Nev.
kingsnjan(at)westnet.com. Guest
Posted: Fri Apr 22, 2011 4:23 pm Post subject: Wing pin mod through flap closeout |
| Quote: | I am pondering this compulsory task,
Tony,
The ONLY reason I didn't use the flap closeout method was because I had
minimal clearance between the closeout and the retracted flap and I wasn't
sure it could accommodate the extra thickness.
Cheers
Kingsley
