sarg314(at)comcast.net Guest
Posted: Sat May 13, 2006 6:31 pm Post subject: panel installation - radio trays |
I am getting down to the little details on panel design and am wondering
about clearance between instruments and my radio stack. The "stack" is
only an SL-30 radio and a KT-76C transponder. I have the trasponder in
hand, but not the radio yet. (I guess it's about time I rodered it.)
I gather these are normally mounted in a some sort of framework that
attaches to the panel but I've never seen one of these. How close can I
realistically place an instrument to this support frame? Does any one
have any photos on their web site that I can look at?
Tom Sargent
RV-6A
walter(at)tondu.com Guest
Posted: Sat May 13, 2006 7:01 pm Post subject: panel installation - radio trays |
I used 3/4" al angle for the frame, behind and attached to the panel.
I suppose you could use 1/2" al angle too.
See pics and desc here. Look for entry dated 6/14/04
http://www.rv7-a.com/avionics.htm
Walter Tondu
Flying!
Rick Galati
Joined: 10 Jan 2006 Posts: 90 Location: Lake St. Louis MO.
Posted: Sun May 14, 2006 4:16 am Post subject: Re: panel installation - radio trays |
Tom,
Installing a radio stack is fairly straightforward. I used .032 aluminum angle stock to tie the trays together and to the back of the panel. The two photographs (of my Garmin 430 stack) should give you a fairly good idea of a typical installation whether for 2 trays or 5 trays....the idea is about the same.
http://img101.imageshack.us/img101/3903/radiostack029bh.jpg
http://img101.imageshack.us/img101/527/radiostack031zh.jpg
Rick Galati RV-6A "Darla" 124 hours
.......I gather these are normally mounted in a some sort of framework that attaches to the panel but I've never seen one of these. How close can I realistically place an instrument to this support frame? Does any one have any photos.........I can look at?..........Tom Sargent
bobbyhester(at)charter.ne Guest
Posted: Sun May 14, 2006 5:14 am Post subject: panel installation - radio trays |
Check near the bottom of this page:
http://members.hopkinsville.net/bhester/FinishKitAssyPg2.htm
Please update your address book with my new email address:
bobbyhester(at)charter.net
Surfing the Web, Highspeed now, from Hopkinsville, KY
Visit my web site at: http://www.geocities.com/hester-hoptown/RVSite/
RV7A Slowbuild wings-QB Fuse-XPO360 engine
sarg314 wrote:
Tom Sargent
RV-6A
Posted: Sun May 14, 2006 6:07 am Post subject: panel installation - radio trays |
Great photographs, guys. I think I get the idea. It looks like I'll
have to give the radios a 1/2 to 3/4 margine around the edge.
Thanks very much.
Tom Sargent
Jim Ellis
Posted: Sun May 14, 2006 6:12 am Post subject: panel installation - radio trays |
Go to www.rvwiki.org and look at "Avionics Rack" to see how I mounted the
avionics in my 9-A. There are several pictures that might be helpful.
Jim Ellis
RV9-A, N155T
taxi testing, ready for first flight
charlieray(at)optonline.n Guest
Posted: Sun May 14, 2006 3:00 pm Post subject: panel installation - radio trays |
As an avionics installer by trade, I would recommend placing like .060"
sheet between the trays when you design where the go, If you arent using a
avionics cooling fan like one from troll avionics.... I recommend leaving
that gap for some air flow.. you may think that a 1/8" gap between radios
is unsightly but they will last longer if they are allowed to breath,
especially in a non force-cooled installation. Position the trays with the
.060 sheet and then take it out when doing final assembly of your racks.
Never never never and never place forced cooling into a radio from something
like a NACA duct on the side of the airframe. I recently pulled a 210 apart
to install a Garmin GTX 330 and found that the 530 was being supplied
cooling air from outside the airplane via a ram air vent on the sidewall.
For S's and G's I took the cover off the 530 and looked inside, I found
pieces of grass and corrosion all over the thing that will lead to its early
demise. Cooling air has to be dry! And from inside the airplane.
Charlie
| Quote: | Tom,
is about the same.
