khurst(at)taroom.qld.gov. Guest
Posted: Wed Jan 11, 2006 12:10 am Post subject: Common Grounding -Forest of tabs |
Dear Bob N,
Because I have a removable instrument panel, it seems to me that it
might be a good idea to have a forest of ground tabs on the engine side
of the firewall and the other set affixed to the instrument panel proper
with a heavy connecting wire between them.
If I used say a 10 awg wire to join the two over a distance of about
300mm, would this be likely to give rise to the dreaded ground loop ? I
imagine not but I am not really sure hence my call for confirmation or
otherwise.
Your assistance is much appreciated as always.
Kingsley Hurst in Oz
nuckollsr(at)cox.net Guest
Posted: Wed Jan 11, 2006 5:30 am Post subject: Common Grounding -Forest of tabs |
At 06:10 PM 1/11/2006 +1000, you wrote:
<khurst(at)taroom.qld.gov.au>
Dear Bob N,
otherwise.
Have you looked over the Avionics (panel) ground
bus architecture proposed in the latest revision
to the 'Connection?
This gathering of all panel grounds into a simpler,
lower wire count extension to the firewall sounds
like what you're wanting to do. See:
http://www.aeroelectric.com/Pictures/Grounding/AVG RA.jpg
http://www.aeroelectric.com/Pictures/Grounding/Avionics Bus 3.jpg
Page 18-12 in
http://aeroelectric.com/articles/Rev11/18Audio R11.pdf
and Z-figures in
Posted: Wed Jan 11, 2006 12:07 pm Post subject: Common Grounding -Forest of tabs |
| Quote: | Have you looked over the Avionics (panel) ground
bus architecture proposed in the latest revision |
to the 'Connection?
Have to confess I haven't Bob but will do so now.
Many thanks
Kingsley
