jdubner(at)yahoo.com Guest
Posted: Sun May 14, 2006 2:10 pm Post subject: Canopy Latched Sensor |
| Quote: | I'm not familiar with any specific reflective-type optical sensors
but I'm guessing that would be the way to go.
Following up on my original post here ...
After a couple of weeks of scratching my head, I found the IR HOA0149
Reflective Sensor ($3.36 ea. at DigiKey, see
http://rocky.digikey.com/WebLib/Honeywell%20Sensing%20%26%20Control/Web%20Data/HOA0149.pdf).
I breadboarded a circuit and found that it worked pretty well as long as:
1) The LED was heavily biased (30 or 40 ma. but not 10 or 20).
2) The reflective object was a flat surface (unlike the domed head of
the screw I wanted to use). Even the Phillips slots in the head
diffused the reflective light considerably and reduced the sensitivity.
3) The reflective object was fairly close to the optimum position as
specified in the data sheet. There wasn't a lot of in/out, left/right,
or up/down tolerance on positioning the latch handle relative to the
Reflective Sensor.
In order to turn ON a warning light when the latch handle was out of
position (not latched) an inverter was required so I added a resistor
and transistor. The Reflective Sensor has a poor current transfer ratio
and there is less than one milliampere available to bias the transistor,
sometimes much less depending on position. In order to reliably control
the #382 light bulb in my Canopy Unlatched indicator I decided I needed
a Darlington-connected configuration.
This is where I pulled the plug. I decided it was too complicated and
"touchy" for my real-world application and I'd rather be flying.
Soooooo, I went back to a Cherry microswitch <groan>. Maybe I'll look
at this again in my *next* airplane when I have more freedom in the
mechanical design.
Joe
Joe Dubner
Long-EZ 821RP
Lewiston, ID
On 27-Apr-06 09:21 Joe Dubner wrote:
| Quote: | I'm looking for a better way to implement the canopy unlatched warning
system on a Long-EZ. The standard method is to use a small microswitch
that responds to "canopy latched". (This is not the same as "canopy
closed", which would be easy enough to implement but I want a "latched"
indication.)
Here's an illustration of the standard system:
http://users.lewiston.com/hth/jd/CanopyLockMicroswitch.jpg
When the canopy locking handle is pushed forward (left in the image) far
enough to latch the canopy locking mechanism, the head of the screw on
the handle (at the right in the image) fits in the hole on the latch and
actives the microswitch through its (specially bent) lever.
I'm not happy with the microswitch as it doesn't hold up well under use
and wonder if any Aeroelectric Connection readers can come up with a
better idea. I've searched for optical interrupters but can't find one
with a gap large enough for the head of the relatively large #10 screw.
I'm not familiar with any specific reflective-type optical sensors but
Any ideas?
Joe
Long-EZ 821RP
Lewiston, ID
brian
Joined: 02 Jan 2006 Posts: 643 Location: Sacramento, California, USA
Posted: Sun May 14, 2006 2:33 pm Post subject: Canopy Latched Sensor |
On May 14, 2006, at 3:00 PM, Joe Dubner wrote:
mechanical design.
Sometimes a checklist item is the best solution.
Brian Lloyd 361 Catterline Way
brian-yak AT lloyd DOT com Folsom, CA 95630
Antoine de Saint-Exupry
_________________ Brian Lloyd
brian-yak at lloyd dot com
- Antoine de Saint-Exupery |
