Posted: Mon May 09, 2011 7:43 pm Post subject: B&C fast-ons |
I just checked the B&C website catalog and they
state that their crimp on terminal offerings are
genuine AMP PIDG . . .
harvey4(at)earthlink.net Guest
Posted: Tue May 10, 2011 1:28 pm Post subject: B&C fast-ons |
Talking about Fast-ons, 1/4" female fast-ons seem easy to find, but I can't seem to locate male ones.
Neil
On May 9, 2011, at 10:05 PM, Robert L. Nuckolls, III wrote:
Neil Clayton
Dennis Johnson
Posted: Tue May 10, 2011 2:21 pm Post subject: Re: B&C fast-ons |
I had the same problem with a Fast-On connector attached to a B&C fuse block. The Fast-On was an AMP PIDG model. I was having problems with one of my avionics and was feeling around behind the panel and felt that the connection between the Fast-On and the fuse block for that instrument was hot to the touch. I wiggled it and the problem immediately went away. However, I cut off the Fast-On and crimped on a new one. I had about 350 hours on the airplane at that point. No problems since.
Dennis
Posted: Tue May 10, 2011 3:47 pm Post subject: B&C fast-ons |
At 06:21 PM 5/10/2011, you wrote:
<pinetownd(at)volcano.net>
This anecdote re-enforces the idea posited in my
earlier post. The 'magic' of a fast-on terminal all
happens at the two grooves plowed into the male tab
by the artfully designed and properly applied female
terminal.
One should be cognizant of the force vectors when
installing these terminals. Avoid applying force
perpendicular to the mating tab. If 'wiggles' are
useful, make them in the plane of the tab. Ideally,
the terminals should be pushed straight on.
Posted: Tue May 10, 2011 5:28 pm Post subject: B&C fast-ons |
At 05:25 PM 5/10/2011, you wrote:
How would you like to use them? By convention,
accessories are fitted with tabs, wires are fitted
with females. Tabs for wires are rare.
Digikey shows a blue-PIDG .250" tab at:
http://search.digikey.com/scripts/DkSearch/dksus.dll?Detail&name=66024-6-ND
and a red-PIDG .250" tab at:
http://search.digikey.com/scripts/DkSearch/dksus.dll?Detail&name=66023-2-ND
but they're not cheap.
If you're wanting a single-wire, serviceable splice, consider the
knife-splice. MUCH preferred for splicing.
http://search.digikey.com/scripts/DkSearch/dksus.dll?Detail&name=A1068-ND
http://search.digikey.com/scripts/DkSearch/dksus.dll?Detail&name=A27474-ND
Posted: Tue May 10, 2011 5:44 pm Post subject: B&C fast-ons |
I've been making temporary end-to-end connections as I do wiring mods behind the panel.
After testing and I'm sure the mod is good, I go back and hard crimp.
Question re knife splices....(I bought some the other day with the intention of trying them).
Are they intended for end-to-end splices like I need, in other words knife-splice to knife splice?
Neil
On May 10, 2011, at 9:24 PM, Robert L. Nuckolls, III wrote:
Neil Clayton
Posted: Tue May 10, 2011 6:22 pm Post subject: B&C fast-ons |
At 09:41 PM 5/10/2011, you wrote:
Sure. We used buckets full of them at Cessna for terminating
pigtails on certain accessories fitted with flying leads. A
couple of knife splices covered with some plastic sleeve
held with a tie-wrap was standard production line procedure.
You can leave them in place suitably insulated . . . or if
you're wanting a tidier looking bundle, you can get a very
slim wire-to-wire splice like this.
http://www.aeroelectric.com/articles/Solder_Lap_Splicing/Solder_Lap_Splices.html
But there's no compelling technical reason to cut out knife
splices and replace with PIDG butt splices.
ulflyer(at)verizon.net Guest
Posted: Wed May 11, 2011 9:52 pm Post subject: B&C fast-ons |
Try Altex Electronics - Dallas TX.
You may have to call them but this is where I get most of my crimp on
fasteners. They usually have a good price compared to most other sources.
http://www.altex.com
jerb
| Quote: | >
>Neil
>snip....
