Geoff Heap
Joined: 12 Jan 2006 Posts: 266 Location: Lindenwold, New Jersey
Posted: Sun May 14, 2006 9:02 am Post subject: 701 riveter access problem on firewall vert lower channel |
Hey guys I've just hit an unexpected problem. Two channel doublers are riveted to the vertical lower channel on the firewall. One on each side. They are to support the bungee pin for the nose strut. Because the bungee sits so close, the plans call for the rivets to be pulled from the inside so as to have the dome head near the bungee. The 8 rivets close the fwd edge are a bit tight but O.K. The other 8 rivets are much deeper in and I cannot get a rivet gun or a hand puller in there. How did you do it. The photo guide shows that somebody at Zenith did it. I can shoot the rivets from the outside easy but they really are two close to the bungee for my comfort. Thanks guys........Geoff
Jari Kaija
Posted: Sun May 14, 2006 10:52 am Post subject: 701 riveter access problem on firewall vert lower channel |
| Quote: | Hey guys I've just hit an unexpected problem. Two channel
You mean these one? You can rivet them by "hand riveter". Pneumatic one
won't fit there...
http://www.project-ch701.net/ch701_fuselage/DSC03413.JPG
Posted: Sun May 14, 2006 1:18 pm Post subject: 701 riveter access problem on firewall vert lower channel |
Look in the photo-share for the Zenith list for shots of various designs for
the baffles (including Larry's). Look around Dec 11th, 2005
http://www.matronics.com/photoshare/zenith-list.html#Top
-- Craig
