		| Author | Message |
		| nimbusaviation(at)YAHOO.C Guest
				|  Posted: Sun May 15, 2011 3:47 am    Post subject: throttle actuator authority |   |
				| Setting about carb' rebalance (912) we were puzzled to find the setup unable to achieve full throttle arm position at the carb - i.e. we are about the width of a 1 UKP coin short of the full throttle stop  ~3 mm, and in violation of the rotax setup instructions.
 Tracing this geometrical conundrum back it appears that the slot in the throttle 'quadrant' plate in the cockpit is too short by about ~2cm. Has anyone encountered this? The build manual does not indicate dimensions of the throttle lever, so either there is a mal-position of holes in the arm, or the slot was too short to start with, or both. We have not yet opened the throttle lever box. The aircraft has over 400hrs of normal ops, but we worry we might be a tad short of full rated T/O power.
 There was a small stop installed at idle (cockpit), however with this removed the problem remains.
 Glenn Rainey
 Cumbernauld, Scotland
 G-OJHL
 classic monowheel
		| Back to top |  |
		| charleslaverty(at)googlem Guest
				|  Posted: Sun May 15, 2011 5:12 am    Post subject: throttle actuator authority |   |
				| hi
I had a similar situation, I found that I had slotted the plate at at 90
 degrees & when pushed forward the lever comes down at a angle on the top
 corner. I removed this with a swiss file plus a little bit & got full
 travel. The idle stop is required to prevent strain on the cable thimble
 attachement on the carbs.
 charlie laverty.
 Sent: Sunday, May 15, 2011 12:43 PM
 Subject: throttle actuator authority
  	  | Quote: |  	  |
 Glenn Rainey
 G-OJHL
 classic monowheel
		| Back to top |  |
		| rlborger(at)mac.com Guest
				|  Posted: Sun May 15, 2011 5:53 am    Post subject: throttle actuator authority |   |
				| Glenn,
 If you have sufficient space between the end of the throttle lever and the face of the instrument panel and all that is preventing full throttle travel it the slot in the top of the throttle quadrant, then get a thin file and gently file the slot forward enough to obtain your full throttle opening.  It shouldn't take much additional movement of the throttle lever to get your 3mm at the carbs.
 Be sure you replace your throttle lever idle stop as required by Rotax.
 Blue skies & tailwinds,
 Bob Borger
 Europa Kit #A221 N914XL, XS Tri-Gear, Intercooled 914, Airmaster C/S Prop
 http://www.europaowners.org/forums/gallery2.php?g2_itemId=60232
 http://www.biplaneforumgallery.com/index.php?cat=10046
 Europa Flying!
 3705 Lynchburg Dr.
 Corinth, TX  76208
 Home:  940-497-2123
 Cel:  817-992-1117
 On May 15, 2011, at 6:43, Glenn Rainey wrote:
  	  | Quote: |  	  |
 Glenn Rainey
 G-OJHL
 classic monowheel
		| Back to top |  |
		| budyerly(at)msn.com Guest
				|  Posted: Sun May 15, 2011 3:13 pm    Post subject: throttle actuator authority |   |
				| <?xml:namespace prefix="v" /><?xml:namespace prefix="o" /><![endif]-->  Glenn,
The throttle slot is cut by the builder.  Follow the build manual and  consider following the Rotax manual also.  I build into the 914s a stop for  100% and ensure the forward slot will just bend the throttle cables at full  115%.  For idle, I put a #10 nutplate and a 10-32 flat head screw (a 525  10R-8 to 12 will work also) which is sufficiently long to stop the throttle just  as the carb idle stop is contacted.  Those with vernier style throttles  have a bit of a chore.  You must come up with some method to stop from  bending the idle stop which is a very common rough running and engine failure  problem.
 Please consult the manual and pull the throttle box from the cockpit module  and get the throw correct.  At the end of a project, when our attention to  detail should be peaked and our research impeccable, we all make minor  mistakes.  Double check to be sure.  I have never had a problem with  the stock throttle operating flawlessly.
 Bud Yerly
 Europa Tech Support
 Custom Flight Creations, Inc.
 www.customflightcreations.com
 (813)  653-4989
 [quote]   ---
		| Back to top |  |
