Chicago Area AN Hardware Source?
sean(at)stephensville.com
PostPosted: Sat May 14, 2011 6:22 am    Post subject: Chicago Area AN Hardware Source? Reply with quote
Anyone around the Chicago western suburbs know of a source for AN
Hardware locally? I was spoiled when I was in Arizona. Had a shop a
few minutes drive away. Aircraft Spruce usually gets stuff to me in a
couple days, but there I times when I just wanted to drive and pick it
up same day.
-Sean #40303
Kellym
PostPosted: Sat May 14, 2011 6:29 am    Post subject: Chicago Area AN Hardware Source? Reply with quote
Probably the most convenient to you is at the southern end of your
state, off I-70,
Wicks Aircraft. They seem to be very good on customer service.
Kelly
Hardware locally? I was spoiled when I was in Arizona. Had a shop a few
minutes drive away. Aircraft Spruce usually gets stuff to me in a couple
days, but there I times when I just wanted to drive and pick it up same
day.
-Sean #40303
Kelly McMullen
KCHD
daveleikam(at)wi.rr.com
PostPosted: Sat May 14, 2011 6:40 am    Post subject: Chicago Area AN Hardware Source? Reply with quote
This might be a bit far for you but they are a good source.
http://www.pegasusautoracing.com/advcat.asp?CategoryID=HARDWARE
David Leikam
RV10
Flying
On May 14, 2011, at 9:19 AM, Sean Stephens wrote:
Anyone around the Chicago western suburbs know of a source for AN Hardware locally? I was spoiled when I was in Arizona. Had a shop a few minutes drive away. Aircraft Spruce usually gets stuff to me in a couple days, but there I times when I just wanted to drive and pick it up same day.
-Sean #40303
PostPosted: Sat May 14, 2011 8:20 am    Post subject: Chicago Area AN Hardware Source? Reply with quote
That's not too bad. I'm 1/2 way between O'hare and Rockford on I-90.
So just a straight shot north a bit.
David Leikam
RV10
Flying
> -Sean #40303
Kellym
PostPosted: Sat May 14, 2011 10:48 am    Post subject: Chicago Area AN Hardware Source? Reply with quote
There might be a source at the Rockford airport as well. I know there is
an aircraft accessories shop there for things like magnetos and fuel
injection systems.
On 5/14/2011 9:16 AM, Sean Stephens wrote:
That's not too bad. I'm 1/2 way between O'hare and Rockford on I-90. So
> David Leikam
> RV10
> Flying
>> it up same day.
>> -Sean #40303
Kelly McMullen
KCHD
PostPosted: Sat May 14, 2011 4:23 pm    Post subject: Chicago Area AN Hardware Source? Reply with quote
I don't know his name off hand, but the owner built an RV-7. Great walk in service. They also carry all the high quality hoses and fittings we all like.
If you do stop up give me a call, it would be nice to meet another builder, you'll be right in my neck of the woods.
David Leikam
RV10
Flying
On May 14, 2011, at 11:16 AM, Sean Stephens wrote:
That's not too bad. I'm 1/2 way between O'hare and Rockford on I-90. So just a straight shot north a bit.
> David Leikam
> RV10
> Flying
>> -Sean #40303
efdsteve(at)aol.com
PostPosted: Mon May 16, 2011 11:20 am    Post subject: Chicago Area AN Hardware Source? Reply with quote
Try Poplar Grove Airmotive Parts Department, just north of Belvidere at the Poplar Grove Airport.
Steve Weinstock
Schaumburg, IL
40230, finishing
