Ryton sumps
Goto page 1, 2  Next
bkbrown(at)ashcreekwirele
PostPosted: Mon May 15, 2006 6:35 am    Post subject: Ryton sumps Reply with quote
Yesterday, I joined the ranks of people who have broken their ryton =
sumps during startup. 3 out of 4 ryton sumps on the field have now =
broken at least once. I am not comfortable with that record, so am now =
looking at alternatives for replacement.
Does anyone have feedback on what options are out there for a forward =
facing sump?
Bob Brown
RV7A
last few things...oh, and a NEW INDUCTION SYSTEM!
Gary.A.Sobek
PostPosted: Mon May 15, 2006 4:08 pm    Post subject: Ryton sumps Reply with quote
There are several out there.
ECI makes a metal one that I saw at Oshkosh and it was several pounds ligher
than the one Lycoming sells.
This is ECI's experimental one:
http://www.eci2fly.com/exp/cis_flyer.pdf
http://www.eci2fly.com/exp/cis_tds.pdf
http://www.superflite.com/products.asp?p=115&SID=17&SN=Front%20Servo%20Sump
I thought that Raven Aircraft also had a 4 cylinder parallel valve version
but cannot find it anymore. Only the 540 version.
http://www.ravenaircraft.com/raven_012.htm
http://www.skydynamics.com/maxisump.html
http://users.adelphia.net/~aeroengine/Barrett.html
http://www.attawayair.com/eci_fi_system.htm
http://www.performanceengines.com/images/LineCard.pdf
I remember seeing a link to another one out there but cannot find it now.
Lets put this one in the archives for next time when we go looking for cold
air sumps.
Gary A. Sobek
"My Sanity" RV-6 N157GS O-320 Hartzell,
1,852 + Flying Hours So. CA, USA
http://SoCAL_WVAF.rvproject.com
----Original Message Follows----
From: "Karen and Robert Brown" <bkbrown(at)ashcreekwireless.com>
Reply-To: rv-list(at)matronics.com
To: <rv-list(at)matronics.com>
Subject: Ryton sumps
Date: Mon, 15 May 2006 06:38:12 -0700
facing sump?
Bob Brown
RV7A
DOUGPFLYRV(at)aol.com
PostPosted: Mon May 15, 2006 5:22 pm    Post subject: Ryton sumps Reply with quote
We also had a broken sump on the Superior XP-360. I don't even know if it is
a Ryton. It has been replaced but I am very leery of it now. Seems we were
running a bit lean at low power.
It back fired on start up. Our servo was a repaired unit so we got a new one
but not sure it is any different. Please give me some input if u are running
the same engine.
1. What is the fuel flow at take off power....we show 16.3 GPH.
2. What are the EGT's at some altitude at full rich.
3. What are the EGT's at that altitude after leaning on the rich side
Appreciate any and all info on this engine. We are not confident that things
are as they should be and concerned with causing damage.
Doug Preston
RV-7A N196VA
PostPosted: Tue May 16, 2006 7:24 am    Post subject: Ryton sumps Reply with quote
Doug,
If your sump is forward facing and it was made by Superior, it's a Ryton =
(composite) sump. If it's metal, it's not Ryton.
Mine broke during a test of the engine. Since the plane has not flown =
yet, I can't give you the fuel flow info you requested. You are =
expressing the same reservations I have on the Ryton sump. When =
everyone else breaks a sump, you wonder what they did wrong. When it =
happens to you after you've tried to do everything right, you realize =
what a fragile link to the chain that sump is. I don't think I could be =
comfortable flying behind one until there is a re-design out there. For =
the life of me, I don't know why that hasn't been accomplished yet. =
It's not like Superior doesn't know they have a problem with these =
things.
What type of ignitions are you running? If you are running electronic =
ignitions, you need to read and understand the SB posted on Superior's =
website regarding the wasted spark ignitions (Lightspeed, Jeff Rose, P/E =
Mags) and Ryton sumps.
bob
rv7a - last few things
Jerry Cochran
PostPosted: Tue May 16, 2006 8:10 am    Post subject: Ryton sumps Reply with quote
Guys,
Please post your messages concerning these sumps also on
_http://groups.yahoo.com/group/XP-360Forum/_ (http://groups.yahoo.com/group/XP-360Forum/) . I am
sure the guys at Superior check that one so important they know what the
sentiment is out here. Last time I talked to them about these failures, they
assured me "It's never happened in flight." Cold comfort. They also said they're
working on a replacement, but not free to present owners unless you "have a
problem". These folks need to step up, communicate with their customers, and
schedule free replacements when available. Mine is still in the garage, but
90/90, so I hope they get off their duff. My .10.
Jerry Cochran
Wilsonville, OR
In a message dated 5/16/2006 12:06:17 A.M. Pacific Daylight Time,
rv-list(at)matronics.com writes:
Time: 06:22:24 PM PST US
Subject: Re: Ryton sumps
is
one
the same engine.
things
Doug Preston
RV-7A N196VA
Jerry Cochran
PostPosted: Tue May 16, 2006 8:13 am    Post subject: Ryton sumps Reply with quote
Bob and Doug,
Superior has told me these incidents have only happened with electronic
ignitions. Is that what you guys have? Something about the "wasted spark"... Even
though I have mags, still makes me nervous as hell...
Jerry Cochran
Wilsonville, OR
facing sump?
Bob Brown
RV7A
pitts_pilot(at)bellsouth.
PostPosted: Tue May 16, 2006 12:27 pm    Post subject: Ryton sumps Reply with quote
That doesn't make sense to me at all. Why would a spark (at any time)
cause a failure of the oil sump???? I'd love to see the data on that one!!!
Linn
Jerry2DT(at)aol.com wrote:
Bob and Doug,
Jerry Cochran
Wilsonville, OR
facing sump?
Bob Brown
RV7A
PostPosted: Tue May 16, 2006 12:43 pm    Post subject: Ryton sumps Reply with quote
Bob, we do have the Ryton composite sump. Superior tells us that ours was #
11 to break. We are running slick mags. Very frustrating. They do not have an
aluminum sump. If this happens in flight it will be bad news......litigation
to follow. They need to get on the stick. We have 12 hours on the 7A so far.
Good luck.
Doug
DO NOT ARCHIVE.
truflite(at)yahoo.com
PostPosted: Tue May 16, 2006 3:17 pm    Post subject: Ryton sumps Reply with quote
What happens in the wasted spark ignition is that
there are two sparks to a complete cycle. The first
is at the top of the compression stroke. The second
is at the top of the exhaust stroke and the opening of
the intake valve. If the spark hits the fuel/air
mixture at this point, a back fire occurs towards the
carb or throttlebody and the ryton sump cannot contain
the explosive condition, therefore, it disintegrates.
Dave
spark (at any time)
Linn
>Bob and Doug,
hell...
>Jerry Cochran
>Wilsonville, OR
Daylight Time,
Brown"
>facing sump?
>Bob Brown
>RV7A
browse
Subscriptions page,
FAQ,
Admin.
ronlee(at)pcisys.net
PostPosted: Tue May 16, 2006 4:28 pm    Post subject: Ryton sumps Reply with quote
I don't believe this. How much ignitable fuel/air mixture can be there?
Plus the exhaust valve is likely open.
And it does not explain Doug's case were he has two mags.
Ron Lee
Dave
lifeofreiley2003(at)yahoo
PostPosted: Tue May 16, 2006 5:36 pm    Post subject: Ryton sumps Reply with quote
In any case, I personally do not like the idea of a poly/plastic media containing my engines blood (oil). These engines are expensive! When I first saw the Ryton sump it looked like a problem just waiting to happen. Just my .02 cents...
Darrell
Ron Lee
Dave
Blab-away for as little as 1/min. Make PC-to-Phone Calls using Yahoo! Messenger with Voice.
New Yahoo! Messenger with Voice. Call regular phones from your PC and save big.
mannanj(at)alltel.net
PostPosted: Tue May 16, 2006 5:49 pm    Post subject: Ryton Sumps Reply with quote
"I don't believe this"
Ron:
Here's my two cents.
The forward facing sump means that the engine is fuel injected. This =
condition happens when the boost pump is left on too long with the =
mixture in the rich, or other than idle cut off position. Raw fuel is =
sent thru the injector nozzles into the intake area ahead of the valve =
and drains down the intake tubes into the air plenun below the oil sump.
What happens next is that the electronic spark system which fires on two =
of the four strokes of the combustion cycle,
(unlike conventional ignition systems which fires only one time in the =
four cycle circuit), fires when there is an open path to the plenum, =
intake valve slightly open. If conditions are right, a flame front =
travels down the intake tube into the plenum igniting an explosion.
It doesn't take much. I have seen a demonstration put on by the local =
firefighters where one drop of gasoline created an ear-spliting bang.
You've seen, or at least heard of backfires on engine starts with =
regular mags too, i'm sure. Pretty much the same thing happening there =
too.
Probably not likely to happen in flight, but you couldn't give me one of =
those things.
Mannan Thomason
RV-8 N161RL (No. One Girl)
Almost flying
gmcjetpilot(at)yahoo.com
PostPosted: Wed May 17, 2006 2:17 am    Post subject: Ryton sumps Reply with quote
Didn't Superior just sell the company off to a German company.
My experience in the past when a company has a massive design problem with their product line, they end up selling it off to another company, who of course does not support the old line. Both times in the past it was with electronic items not engine parts. Is that an effort to avoid liability? I wounder it the German company knew about this before they bought it?
Not saying this is Superior's reason for the buy out, but I see this time and time again, a company sell off ownership preceded by some massive design or QC screw up of a product or line of products.
I guess there is something to be said for certified parts that have stood the test of time.
George RV-7
Rhonda(at)bpaengines.com
PostPosted: Wed May 17, 2006 6:39 am    Post subject: Ryton sumps Reply with quote
Our Cold air system is available only on the IO-540. We designed and
build them as an experimental replacement for the Lycoming certified
cold air sump (which costs approx. $8500) for any model parallel or
angle head IO/AEIO-540.
We do not have a cold air sump for the 360 engines. We tested some many
years ago and found that there was no performance enhancement, so we
decided not to pursue.
The IO-540 Cold Air System sells for $3995 as a stand alone unit, $3495
with an engine purchase.
Rhonda Barrett-Bewley
Barrett Precision Engines, Inc.
2870-B N. Sheridan Rd.
Tulsa, OK 74115
(918) 835-1089 phone
(918) 835-1754 fax
www.barrettprecisionengines.com
Here's the deal:
If you want a "cold air sump", there seems to be 3 choices-
Ryton sump by Superior
Magnesium sump by ECI
Barrett Precision cold air sump
All the other metal sumps out there-
Aerosport Power
Aero Engines
Superflite
Are all copies of the Lycoming cast aluminum sump (not cold air sumps)
I don't have the information on the Barrett Cold Sump system, but it is
the most expensive of the three. I'll post that here when I find it.
rvbuilder(at)sausen.net
PostPosted: Wed May 17, 2006 8:43 am    Post subject: Ryton sumps Reply with quote
Just as an FYI, I know many vendors don't like to come off as pushing =
their products on the lists so I thought I would forward this.....
Michael Sausen
RV-10 #352 Working on Fuselage
PostPosted: Wed May 17, 2006 9:27 am    Post subject: Ryton sumps Reply with quote
This is huge news.
Up to now everyone has been repeating the mantra that the problems with =
the Superior ryton sump have only occurred while coupled with electronic =
ignitions utilizing wasted spark technology. If one has failed with =
mags, then I would think all those people running Lasar ignitions are =
now also under the same shadow of risk. Doug, do you have additional =
details like when/how the failure occurred? A photo posted somewhere =
would be most enlightening.
For those of us in the same situation, I believe we should all write to =
Tim Archer, president of Superior, as well as Frank Thielert, who just =
bought Superior, and express our concerns for a rapid solution to this =
issue. They should pull the sumps off the market now and inform all =
owners of the possibility of failure and the need to inspect the =
induction system at the end of each flight. At the same time they need =
to recognize the need/market for a reliable, lightweight cold air =
induction system. Come on guys, this isn't rocket science.
Since I have totally lost confidence in the Ryton sump (as it's =
currently manufactured), the solution I have been forced into is to try =
(and I mean try...since there are none currently available anywhere) and =
purchase an aftermarket cast aluminum forward facing sump. I am told =
the shortest lead time is several weeks, with no firm delivery date. At =
the time I receive it, I'll then have to completely re-do the fiberglass =
snorkel, the fuel lines and linkages to compensate for the different =
geometry of the two sumps. Superior is apparently willing to cover =
$1000 for reimbursement of my old sump. The new one will cost about =
$2200, so besides the lost 100 hours or so of labor, I'll be out an =
additional $1500 dollars or so.
bob brown
rv7a
last few things, and a new induction system.
recapen(at)earthlink.net
PostPosted: Wed May 17, 2006 9:49 am    Post subject: Ryton sumps Reply with quote
A few letters to them might help....
A few other letters might help also......EAA, AOPA, FAA
PostPosted: Wed May 17, 2006 10:44 am    Post subject: Ryton sumps Reply with quote
I am posting this letter I received from Bill Wallace, multiple RV =
builder and EAA Tech Counselor:
Doug;
My neighbor, Bob Brown forwarded your message to me this morning... =
Sorry to hear the bad news.
I also have a ryton sump in my RV8A along with LASAR Ignition, so far, =
(80) hours), I have not had any problems. However, with your revelation =
my confidence level has diminished substantially and I would like to ask =
you for some specific detail of your sump failure. For example, was it =
on a "hot Start", did it blow out a chunk or crack, did you actually =
hear it blow, or any additional detail you may think pertinent.
I have a hard time buying that there have been "only" 11 sump failures, =
we have had four failures out of a population of four ryton sump =
Superior engines here at the Independence Airpark alone! Denny =
Jackson's RV8 has two failures, (aft/lower air sump blow-outs) with a =
dual Jeff Rose electronic ignition system, on "hot " starts; Ron =
Russell had a failure (Light speed ignition), that made his engine run =
"a little' rough at idle, he subsequently flew home and upon landing =
could hardly keep it running long enough to get to his hangar. His sump =
had jagged fore to aft opening along the entire bottom of his air sump. =
Unfortunately, Ron Russell is no longer with us, so further detail is =
not available. Bob Brown's sump cracked at the mating line of the air =
sump and oil sump without any audible backfire, (on a second engine test =
run).
This is our local history at this time. I am fully supportive of any =
methods we could legally come up with to get Superior's attention and =
quick resolution to this faulty ryton sump problem.
Bill Wallace
EAA Technical Counselor
bswal(at)msn.com
PostPosted: Wed May 17, 2006 11:01 am    Post subject: Ryton sumps Reply with quote
My partner (A&P) was starting the engine and it backfired and blew the
bottom out of the induction plenum. He called Superior and they told him it was
the 11th, but all the others were with electronic ignition. Supposed to be about
200 engines on service. Probably not likely to happen in flight but I don't
feel good about it.
Doug
BPA(at)bpaengines.com
PostPosted: Wed May 17, 2006 11:36 am    Post subject: Ryton sumps Reply with quote
Regardless of what type of ignition source you have, or, which sump you
have be it a Ryton, ECI, Lycoming, or Happy Joes from Kokamoe, if the
electric boost pump is used to prime the engine, you are getting fuel in
the intake plenum, plane (only spelling I know :)and simple! That is the
reason for the drain (sniffle valve). It is important that the sniffle
valve be located in the LOWEST spot on the induction part of the system,
with the plane at it's natural resting attitude. You have to realize
that if the pump is turned on say for 5 seconds, you have to wait until
you are confident that any excess fuel in the plenum has drained before
you crank the engine. This is in my opinion the cause of the Ryton
issue.
Allen Barrett
BPE, Inc
Goto page 1, 2  Next
Page 1 of 2
