gerf(at)gerf.com Guest
Posted: Mon May 15, 2006 7:29 am Post subject: Instrument screws/nuts |
Folks,
I'm assuming that brass screws are what to use anywhere on the
panel (although all my instruments are "electronic" apart from
2 steam gauges - altimeter and ASI).
I see various brass screws in Spruce's catalog - but no brass
nuts and washers - do folks generally go with the cad plated
steel locknuts (AN365) ? Or is there a source of brass nuts
and washers ?
__g__
Gerry Filby gerf(at)gerf.com
Tel: 415 203 9177
flyeyes(at)mac.com Guest
Posted: Mon May 15, 2006 7:53 am Post subject: Instrument screws/nuts |
On May 15, 2006, at 10:28 AM, Gerry Filby wrote:
Folks,
and washers ?
Gerry-
The only reason to use the brass hardware is to avoid interference
with your compass. If you don't have a compass on your panel, don't
worry about it.
Stainless nuts and washers are widely available and mostly (but not
completely) non-magnetic. These are usually good enough for "gubmint"
work.
For items that won't be removed frequently, don't overlook soft
aluminum pop rivets. They are quick and cheap to install, and can be
drilled out more quickly than you can remove a typical threaded
fastener. I used them to mount my magnetometer rather than fool
around trying to find appropriate brass or nylon hardware.
James Freeman
denis.walsh(at)comcast.ne Guest
Posted: Mon May 15, 2006 7:54 am Post subject: Instrument screws/nuts |
Grasshoppers or threaded instruments
Denis Walsh
On May 15, 2006, at 9:28 AM, Gerry Filby wrote:
Folks,
and washers ?
__g__
Tel: 415 203 9177
pbesing(at)yahoo.com Guest
Posted: Mon May 15, 2006 5:16 pm Post subject: Instrument screws/nuts |
I just used some really cool stainless hex head screws
from home depot. Works great. I think the brass
screw thing is an old wives tale, personally...that is
unless you are using them screw in a compass.
Paul Besing
--- James Freeman <flyeyes(at)mac.com> wrote:
<gerf(at)gerf.com>
> Folks,
anywhere on the
but no brass
cad plated
brass nuts
> and washers ?
Gerry-
avoid interference
your panel, don't
worry about it.
mostly (but not
work.
overlook soft
install, and can be
typical threaded
rather than fool
hardware.
James Freeman
browse
Subscriptions page,
FAQ,
Admin.
