JohnF
Posted: Mon Jun 06, 2011 8:19 am Post subject: Rotax 912ULS Prop Settings |
I have been adjusting, then flying the RV-12 with trial and error Sensenich ground-adjustasble prop blade settings. I believe I now have the prop about where it should be. Here are the results of today's trial from KANK airport at 7525-ft msl, density altitude 9,800-ft:
Take off climb at 68-mph WOT showed 5,040 rpm (climb rate 650 fpm +)
Level flight at 8.870-ft msl showed 5,550 rpm
Two 180-degree legs showed:
IAS 110/110
TAS 129/127
GPS 142/121
Will leave things as they are and check again from time to time.
Thanks, Roger for your information regarding this sort of thing.
John
lucien
Joined: 03 Jun 2007 Posts: 721 Location: santa fe, NM
Posted: Tue Jun 07, 2011 5:18 am Post subject: Re: Rotax 912ULS Prop Settings |
| JohnF wrote: | I have been adjusting, then flying the RV-12 with trial and error Sensenich ground-adjustasble prop blade settings. I believe I now have the prop about where it should be. Here are the results of today's trial from KANK airport at 7525-ft msl, density altitude 9,800-ft:
IAS 110/110
TAS 129/127
GPS 142/121
John
Sounds slightly overpropped to me? I think rotax wants at least 5200 rpm when running at WOT so 5000 sounds like its lugging a bit?
I too fly at a high altitude (northern new mexico, where the ground is about 7000' MSL) so I prop my 912ULS (titan tornado) for climb at about 5200 at Vx (65 to 70mph) and it unloads to about 5400 at 80mph. OTOH, my prop is gigantic, a powerfin F model, 70" 3-blade. The powerfin is notorious for having a narrow speed range, in my experience, but nothing generates better climb performance. So it'll easily hit redline in level flight when pitched for good climb.
Anyway, just a thought? I'd think 5000 would be a bit too heavy....
LS
_________________ LS
Titan II SS |
