Rob Henderson
Posted: Fri Jun 10, 2011 9:59 am Post subject: Shrink Tubing |
Hi All
I have a small surplus of large heat shrink
CANUSA 1500 and 1700
I have 54' of 1500 and 45 of 1700
I will cut as necessary.
I will let it go at $2.00/Ft. + Shipping
Contact
robnrobinh(at)comcast.net
Rob Henderson
6020 97th Dr NE
Lake Stevens, WA. 98258
Canusa
CFvT-1500
1.5 " Black Heat Shrink, Glue Lined (Encapsulant Lined)
CFTV tubing is the leading method of protecting cables and splices for CATV applications.
CFvT-1700
1.75" Black Heat Shrink, Glue Lined (Encapsulant Lined)
Features and Benefits
• Craft friendly installation
• Exceptional split resistance
• CFTV adhesive retains bond providing long term protection
• Minimal heat required to produce error free installation without splitting
• Thermochromatic lines change color to signal waterproof seal
• Shrink ratio: 3:1
• Continuous operating temperature: -55 Deg C to 110 Deg C
Dimensions
Shrink Ratio: 3 to 1
Expanded Internal Diameter (min.): 38.1 mm, 1.50 inch
Recovered Internal Diameter (max.): 12.7 mm, 0.50 inch
Recovered Wall Thickness (nom.): 2 mm, 0.08 inch
Application Range for General Use: 14.0- 35.0 mm, 0.55- 1.4 inch
When the shrink sleeve reaches the target temperature, the sleeve recovers, the sealant flows and the thermocromatic paint changes color, a waterproof barrier is formed.
18.42 KB |
2453 Time(s) |
