M14PEngines-List Digest: 4 Msgs - 06/17/11
Post new topic   Reply to topic    Matronics Email Lists Forum Index -> M14PEngines-List
sapril001(at)hotmail.com
PostPosted: Sun Jun 19, 2011 6:24 am    Post subject: M14PEngines-List Digest: 4 Msgs - 06/17/11 Reply with quote
Hi all,
I have this question about the�V-530 prop.
When you are running the engine on the ground,�about 1600 RPM and you cycle the prop from fine to coarse, what should you expect, a drop on RPM?
How can you make sure the prop control�is working well while you are on the ground?
Sylvain April
> Date: Fri, 17 Jun 2011 23:56:58 -0700
[quote] From: m14pengines-list(at)matronics.com
To: m14pengines-list-digest(at)matronics.com
Subject: M14PEngines-List Digest: 4 Msgs - 06/17/11
Today's complete M14PEngines-List Digest can also be found in either of the
of the M14PEngines-List Digest and can be viewed with a generic text editor
HTML Version:
http://www.matronics.com/digest/digestview.php?Style=82701&View=html&Chapter=2011-06-17&Archive=M14PEngines
Text Version:
http://www.matronics.com/digest/digestview.php?Style=82701&View=txt&Chapter=2011-06-17&Archive=M14PEngines
M14PEngines-List Digest Archive
Total Messages Posted Fri 06/17/11: 4
Today's Message Index:
1. 06:23 AM - M-14P EGT (Sylvain April)
2. 06:49 AM - Re: M-14P EGT (George Coy)
3. 07:19 AM - Re: M-14P EGT (Monty Barrett Sr)
4. 03:18 PM - V-530 Two Blade Propeller For Sale (cd001633)
________________________________ Message 1 _____________________________________
Time: 06:23:59 AM PST US
Subject: M-14P EGT
Hi all=2C What should be the red line for the EGT on a M-14P engine. Sylvai
n AprilMurphy Moose M-14P
________________________________ Message 2 _____________________________________
Time: 06:49:54 AM PST US
Subject: RE: M-14P EGT
2,950 RPM at the crankshaft or 1,860 RPM at the propeller.
George Coy
CAS Ltd.
714 Airport Rd.
Swanton VT 05488
802-868-5633 off
802-363-5782 cell
802-868-4465 Fax
george.coy(at)gmail.com
http://coyafct.com/
SKYPE george.coy
From: owner-m14pengines-list-server(at)matronics.com
[mailto:owner-m14pengines-list-server(at)matronics.com] On Behalf Of Sylvain
April
Sent: Friday, June 17, 2011 9:21 AM
Subject: M14PEngines-List: M-14P EGT
Hi all,
Sylvain April
Murphy Moose M-14P
________________________________ Message 3 _____________________________________
Time: 07:19:30 AM PST US
I have never seen a limitation published on EGT for aircraft engines.
There are turbine inlet temp. limits but not EGT.
IN our test cell we have seen up to 1525 F but that was at Cruise 1
power and maximum lean. Typical full power EGT when the carb is
correctly jetted will give around 1450 F.
EGT is a variable and depends on a lot of physical characteristics
besides fuel-air ratio. Iti should be used as a trend monitoring
temperature.
Monty Barrett
Barrett Precision Engines, Inc.
- The Matronics M14PEngines-List Email Forum -
http://www.matronics.com/Navigator?M14PEngines-List
dsavarese0812(at)bellsout
PostPosted: Mon Jun 20, 2011 2:54 am    Post subject: M14PEngines-List Digest: 4 Msgs - 06/17/11 Reply with quote
Sylvan,
At 1600 RPM the prop most likely will not cycle. You need to run the
engine up to around 2000-2050 RPM and them attempt to cycle the prop.
(This is the same RPM recommended for the magneto check). If the prop
governor is set to spec and functioning properly, the RPM should drop to
around 1550 RPM.
Dennis
On 6/19/2011 9:21 AM, Sylvain April wrote:
[quote] Hi all,
I have this question about the V-530 prop.
When you are running the engine on the ground, about 1600 RPM and you
How can you make sure the prop control is working well while you are
on the ground?
Sylvain April
of the
formatted
editor
> HTML Version:
http://www.matronics.com/digest/digestview.php?Style=82701&View=html&Chapter 11-06-17&Archive=M14PEngines
> Text Version:
http://www.matronics.com/digest/digestview.php?Style=82701&View=txt&Chapter 11-06-17&Archive=M14PEngines
> From: Sylvain April <sapril001(at)hotmail.com>
> Subject: M-14P EGT
Sylvai
> From: "George Coy" <george(at)gesoco.com>
> George Coy
> CAS Ltd.
> 714 Airport Rd.
> Swanton VT 05488
> 802-868-5633 off
> 802-363-5782 cell
> 802-868-4465 Fax
> http://coyafct.com/
> SKYPE george.coy
Sylvain
> April
> Subject: M-14P EGT
> Hi all,
> Sylvain April
> Murphy Moose M-14P
> From: "Monty Barrett Sr" <MONTY(at)bpaengines.com>
> temperature.
> Monty Barrett
Post new topic   Reply to topic    Matronics Email Lists Forum Index -> M14PEngines-List All times are GMT - 8 Hours
