sean(at)stephensville.com Guest
Posted: Tue Jun 21, 2011 7:59 am Post subject: Getting Snap Bushing On Tube With Fittings |
What is the proper procedure for getting a snap bushing around tubes
that already have fittings? I have a -6 line that I had made for fuel
under the front seats and I'd like to place snap bushings for the two
brackets the original went through. Do you just split the snap bushing
in half?
-Sean #40303
AirMike
Posted: Tue Jun 21, 2011 9:08 am Post subject: : Getting Snap Bushing On Tube With Fittings |
Just cut them and slip on the tube. No problem.
_________________ See you OSH '18
Q/B - sold. |
rleffler
Posted: Tue Jun 21, 2011 9:12 am Post subject: Getting Snap Bushing On Tube With Fittings |
Or just a single cut....
On Jun 21, 2011, at 11:56 AM, Sean Stephens <sean(at)stephensville.com> wrote:
What is the proper procedure for getting a snap bushing around tubes that already have fittings? I have a -6 line that I had made for fuel under the front seats and I'd like to place snap bushings for the two brackets the original went through. Do you just split the snap bushing in half?
-Sean #40303
_________________ Bob Leffler
N410BL - Phase I
Albert Gardner
Posted: Tue Jun 21, 2011 9:14 am Post subject: Getting Snap Bushing On Tube With Fittings |
I just cut it on the band saw on the side between the fingers that hold it
in place.
Albert Gardner
N991RV
Yuma, AZ
_________________ RV-9A N872RV
RV-10 N991RV |
Posted: Tue Jun 21, 2011 9:41 am Post subject: Getting Snap Bushing On Tube With Fittings |
Thanks everyone...
-Sean
in place.
Albert Gardner
N991RV
Yuma, AZ
