		wildirishtime
				 Posted: Fri Jun 24, 2011 7:22 am    Post subject: EGT Probe location for a 912ULS? |
				One place in the Install manual it shows 3.93" from the head/flange, but it's unclear HOW EXACTLY you're measuring that (center of the exhaust in a bent tube, outside of the arc, inside of the arc)? that creates a lot of variation and potentially a lot of distance.
 Then in some other documentation I see it says 2.76" from the head.... something I found online...
 confusion, confusion. Can someone tell me EXACTLY where those darn EGT probes are supposed to be drilled in and how to measure it for most accurace location?
 Thanks!
 ~Wild
  |  | - The Matronics RotaxEngines-List Email Forum - |  |   |  Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
		Roger Lee
				 Posted: Fri Jun 24, 2011 2:36 pm    Post subject: Re: EGT Probe location for a 912ULS? |
				You have it at 3.93. Measure from the center of the tube at the flange and straight back along the side. Mark it and drill it. If you need to clear something with the outside probe end then angle it up or down. You'll be good to go.
  _________________ Roger Lee
Tucson, Az.
Rotax Instructor & Rotax IRC
Light Sport Repairman
Home 520-574-1080  TRY HOME FIRST
Cell 520-349-7056 |
		wildirishtime
				 Posted: Sun Jun 26, 2011 2:00 pm    Post subject: Re: EGT Probe location for a 912ULS? |
				What exactly do you mean by "straight back along the side"?  The arc length of the outside of the tube would be drastically different than the arc length of the inside of the tube...... so should I calculate the arc length in the 'center' of the tube as you initially mentioned?
 Thanks!
		rampil
				 Posted: Tue Jul 05, 2011 7:20 am    Post subject: Re: EGT Probe location for a 912ULS? |
				The distance is along the upper surface of the exhaust pipe.
 I would not go too crazy on exactitude since GA grade EGT meters
 are not terribly accurate anyway, i.e., ± 50°C out of the box without
 careful calibration.
 The main idea is to have all the EGTs installed at the same relative
 distance from the valve so they are comparable. (I have 4 EGTs
 and 4 CHTs on my 912s into my Blue Mountain)
