Aircraft angle of Incidence in flight and engine cooling
jeffrey_davidson(at)earth
PostPosted: Sun Jun 26, 2011 5:16 pm    Post subject: Aircraft angle of Incidence in flight and engine cooling Reply with quote
Interestingly, I have just put a deflector over cylinder number two on my Jabiru 3300 (solid lifters & wide fins). I had the temperatures pretty well straightened out, but in cruise at 2800 RPM number 2 would heat up. I tested the deflector today with good results so far. Now the odd side could get a little lower. Mine are the air plenums with the holes for the spark plugs. Later ones cover the spark plugs and the wires. Mine will be at Oshkosh!
Jeff D
