elledien
Posted: Sat Jun 25, 2011 11:25 pm Post subject: Antenna |
Hello everybody.
I wish to improve my radio ,Icom IC-A200, performance.
Practically the range is very limited and I have a lot of noise in trasmission.
The reception is good, strong and without noise on all frequencies.
The whole radio system seems to be correct, radio,connectors...
The problem arises with the antenna. The antenna, a whip model, is on the belly with a ground panel inside the fuselage.
The problem, I believe, is here.
So, I ask, which kind of antenna did you install and the results obtained.
At the moment I haven't any Residual wave measurements so I cannot answer to the request.
Thank-you
Luigi
Esqual I-9854
| | - The Matronics Lightning-List Email Forum - | | | Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
http://www.matronics.com/Navigator?Lightning-List |
davemcc
Posted: Sun Jun 26, 2011 3:51 pm Post subject: Antenna |
Luigi
I also have an Esqual, I also tried the antenna under side mount with a copper plate, another on top, another in the mid aft . I tried it all. Let me tell you what worked for me, do with it what you may.
1- get a good radio, I have had a Garmin SL 40 for about 5 years now
2-Get that antenna mounted as far away from the engine as possible
3-Mount the antenna as verticle as possible- I use an advanced aircraft eletronics antenna that I mounted on the horizontal stabilizer. take off the rudder and epoxy the antenna to the rear inside flange of the stabilizer.
I can talk clear to any airport within 150 miles . Even if you keep your radio, mount the antenna like I did and I know you will be happy
Dave
landjridge(at)775.net Guest
Posted: Sun Jun 26, 2011 4:41 pm Post subject: Antenna |
usually an antenna system which receives normally will also transmit normally I suggest you check transmitter modulation.low modulation gives short range and scratchy sound,over modulation gives distortion and many other problems: lGood luck Lowell Ridge lightning kit # 10310uigi di napoli (elledien(at)yahoo.com)
[quote] To: lightning-list(at)matronics.com (lightning-list(at)matronics.com)
Sent: Sunday, June 26, 2011 12:22 AM
Subject: Antenna
Hello everybody.
Thank-you
Luigi
Esqual I-9854
href="http://www.matronics.com/Navigator?Lightning-List">http://www.matronics.com/Navigator?Lightning-List
| [b]
elledien
Posted: Sun Jun 26, 2011 10:48 pm Post subject: Antenna |
Dave thank-you for the info.
I need more info about the mounting position.
You say to install it as verticle as possibile. Do you mean in the vertical fin or in the horizontal stabilizer? I suppose in the vertical fin.
The antenna you suggest is the Advanced Electronic 5T ?
Thanks again.
Best regards
Luigi
Esqual I-9854
Da: Dave Mccorquodale <corky(at)hbci.com>
A: lightning-list(at)matronics.com
Inviato: Lunedì 27 Giugno 2011 1:48
Oggetto: Re: Antenna
Luigi
Dave
NowackLinden(at)gmx.de Guest
Posted: Tue Jun 28, 2011 6:15 am Post subject: Antenna |
Luigi,
My opinion does not count 100% , since I haven`t tried my radio with engine running so far.
But I have contacted the tower of the airfield I usually fly off ( EDFL, about 10km away ) from my ground floor workshop, with a steel concrete ceiling above me and brick walls around.
Flap and trim motors made no disturbance.
I use a german Filser/Funkwerk 833a COM with a Funkwerk antenna that has been developed especially for the composite gliders ( and powered gliders) that we have so many here in Germany.
It consists of a 65cm wire part and has a short connection cable with a standart plug. I also bought a 5m (thats roughly 15ft for you non-metricals) extension cable and followed the recommendation of the Knowing ( and Dave`s, but I didn`t know of him at that time ) and epoxied it to the aft side of the vertical stab`s bulkhead. There is no need for any alu or copper "counterweights".
The antenna was about 40 Euro + tax.
I don`t think you have to buy a new radio. From what I heard the ICOM radios are ok.
If you´re interested, just mail me and I will tell you where you can buy the stuff in Germany, in case they don`t sell it in Italy.
Which airfield in Italy do you fly from?
Hope this helps!
Gerd
Am 27.06.2011 08:46, schrieb luigi di napoli: [quote] Dave thank-you for the info.
Thanks again.
Best regards
Luigi
Esqual I-9854
Da: Dave Mccorquodale <corky(at)hbci.com> (corky(at)hbci.com)
A: lightning-list(at)matronics.com (lightning-list(at)matronics.com)
Luigi
Dave
| Quote: | ----- Original Message -----
Sent: Sunday, June 26, 2011 2:22 AM
Subject: Antenna
Hello everybody.
Thank-you
Luigi
Esqual I-9854
http://www.matronics.com/Navigator?Lightning-Listw" target="_blank" href="http://www.matronics.com/contribution">http://=======================
| [b]
elledien
Posted: Tue Jun 28, 2011 6:46 am Post subject: Antenna |
Thank you Gerd for your mail with interesting infos.
I leave nearby Rome, 40 km south-east, and the field is Artena.
I tried to find on the web but, right now I found only the extension cable for Funwerk.
I really appreciate if you may tell me where to buy this antenna.
Best regards
Luigi
Da: Gerd + Uli Nowack <NowackLinden(at)gmx.de>
Inviato: Martedì 28 Giugno 2011 16:13
Luigi,
Hope this helps!
Gerd
Thanks again.
Best regards
Luigi
Esqual I-9854
Luigi
Dave
Subject: Antenna
Hello everybody.
Thank-you
Luigi
Esqual I-9854
| http://www.matronics.com/Navigator?Lightning-Listhttp://=======================
You cannot post new topics in this forum You cannot reply to topics in this forum You cannot edit your posts in this forum You cannot delete your posts in this forum You cannot vote in polls in this forum You cannot attach files in this forum You cannot download files in this forum
