ADS-B Transceiver...
Site Admin
PostPosted: Sun Jul 03, 2011 9:49 am    Post subject: ADS-B Transceiver... Reply with quote
At 06:23 AM 7/3/2011 Sunday, you wrote:
Matt can you tell us about the ADS-B receiver? Got a link? I need to start thinking about one.
I ordered the ADS600-B unit from NavWorx:
http://www.navworx.com/ads600-b.asp
Here's their main site:
http://www.navworx.com/index.asp
They're not exactly cheap. Here's the price list:
http://navworx.americommerce.com/store/c/21-Buy-Your-NavWorx-ADS600-or-PADS600-Online-Now.aspx
I also ordered it with the WIFI module and the ARINC-429 for fun.
Matt
http://www.mattsrv8.com/Rebuild - Post Landing Mishap Rebuild Log
Status: 170+ Hours TTSN - Rebuilding Fuselage After Landing Mishap...
ollie6a(at)embarqmail.com
PostPosted: Sun Jul 03, 2011 10:43 am    Post subject: ADS-B Transceiver... Reply with quote
People also might want to check skyradar.net which I have running on
my Iphone. Works great for weather.
Matt
From Central Florida,
 Ollie
BGray(at)glasair.org
PostPosted: Tue Jul 05, 2011 5:08 am    Post subject: ADS-B Transceiver... Reply with quote
Hi Guys,
I already have all the equipment I need for ADS-B Out for my Glasair
III. But it seems that in its rush to get the regulation out to the
public, the FAA did not provide any path for Experimental aircraft to
install/approve ADBS-B.
The FAA has published an advisory circular on the subject (AC 20-165)
that states ALL ADBS-B installations must be approved before use. It
then goes on to state that approval requires an STC. It also broadly
hints that all equipment must be TSO'ed. You all must know that STC's do
not apply to us. To add further confusion, I was told by my local FSDO
that all STC's for approval were not being accepted and that the only
way to get approval was from the original aircraft manufacturer. I asked
the FSDO if we (the home builder) were considered the manufacturer and
was told the FAA felt that it was the kit manufacturer. I called the
EAA, they were clueless.
So, it seems that you (or we) can't get there from here. Any one have
any ideas?
Bruce
WWW.Glasair.org
PostPosted: Tue Jul 05, 2011 5:49 am    Post subject: ADS-B Transceiver... Reply with quote
Woops,
Here's the link to the AC,
http://www.airweb.faa.gov/REGULATORY_AND_GUIDANCE_LIBRARY/RGADVISORYCIRC
ULAR.NSF/0/4D934250FE568A79862577310060CF03?OpenDocument
Bruce
WWW.Glasair.org
dave.saylor.aircrafters(a
PostPosted: Tue Jul 05, 2011 6:03 am    Post subject: ADS-B Transceiver... Reply with quote
Hi Bruce,
I don't think the AC applies to us since it's only for those seeking
TC or STC approval--as you said, we don't have TCs or use STCs.
Which transceiver are you using? Display?
Dave Saylor
AirCrafters
140 Aviation Way
Watsonville, CA 95076
831-722-9141 Shop
831-750-0284 Cell
On Tue, Jul 5, 2011 at 6:46 AM, Bruce <BGray(at)glasair.org> wrote:
Woops,
Bruce
WWW.Glasair.org
pitts_pilot(at)bellsouth.
PostPosted: Tue Jul 05, 2011 6:33 am    Post subject: ADS-B Transceiver... Reply with quote
On 7/5/2011 9:04 AM, Bruce wrote:
Hi Guys,
snip
any ideas?
Yep. Install it like you want it .... and ask forgiveness later. The
only thing I'd put into the 'must do' category is to make sure the
transmitted information being broadcast is accurate. There are already
a lot of ADS-B installations in experimentals.
Linn
[quote] Bruce
WWW.Glasair.org
Tim Olson
PostPosted: Tue Jul 05, 2011 6:44 am    Post subject: ADS-B Transceiver... Reply with quote
To me, the section 1-1(b) says enough to move ahead. If you get it installed, and working properly, you're unlikely to have any worries. And the benefits of it are many.
Tim
On Jul 5, 2011, at 8:46 AM, "Bruce" <BGray(at)glasair.org> wrote:
Woops,
Bruce
WWW.Glasair.org
Tim Olson
PostPosted: Tue Jul 05, 2011 6:47 am    Post subject: ADS-B Transceiver... Reply with quote
Definitely make sure your transmitted info is set up correctly. Other than that, you'll want it to squawk the same code as your transponder....and if you have a gtx330 you're golden. Likely the same with gtx327.
Tim
On Jul 5, 2011, at 9:30 AM, Linn Walters <pitts_pilot(at)bellsouth.net> wrote:
> Hi Guys,
snip
> any ideas?
Yep. Install it like you want it .... and ask forgiveness later. The only thing I'd put into the 'must do' category is to make sure the transmitted information being broadcast is accurate. There are already a lot of ADS-B installations in experimentals.
Linn
> Bruce
> WWW.Glasair.org
PostPosted: Tue Jul 05, 2011 7:02 am    Post subject: ADS-B Transceiver... Reply with quote
Garmin 530W, Garmin 330 transponder updated for ADBS-B Out, and a RMI
microencoder/air data unit. All are TSO'ed except the RMI air data
system.
I still believe it has to be approved because it transmits position data
to ATC. We just can't install and turn it on, at least that's what the
FSDO tells me. There is no in flight approved testing procedure in place
yet, and no one has the ground testing equipment to verify the
transmitted data blocks around here.
Bruce
WWW.Glasair.org
Kellym
PostPosted: Tue Jul 05, 2011 7:24 am    Post subject: ADS-B Transceiver... Reply with quote
Another example of the FAA left hand not having a clue what the right
hand is doing. Your transponder and GPS are TSO. That means the position
information complies with the requirements. Your air data system has to
meet a different regulation, and I assume it does if it passes an IFR
static system check.
Too many FAA inspectors have no experience/training on experimental
aircraft side of the house, and rather than linking you up with someone
who does, try to bluff their way into making the problem go away.
Just read an idiot article today on the "new" air traffic system that
once again says ADSB/Next Gen will replace radar. If that were true, we
wouldn't be required to have either Mode A/C transponders or Mode S in
addition to UAT. The FAA wouldn't have gone to the totally stupid dual
frequency system. Also article said lots about airlines not wanting to
spend the money, without one mention of GA and who pays for that. Grump,
grump.
Maybe Das Fed (if he isn't too busy stomping out office brushfires) can
shine some light on the subject for us and send something off to the
author of the AC to remind them they need to deal with experimental
installs as well if they want the air traffic system to retain
integrity. Not that I want more fed involvement, but really is necessary
on something that affects all aircraft.
system.
Bruce
WWW.Glasair.org
Kelly McMullen
KCHD
Tim Olson
PostPosted: Tue Jul 05, 2011 7:31 am    Post subject: ADS-B Transceiver... Reply with quote
But all over that document it says "a position source meeting the minimum performance requirements of any revision of TSO-C129, TSO-C145, TSO-C146, or TSO-C196...)
So it says all over that it needs to meet the performance reqs but doesn't say it has to BE TSO'd. I won't go on further other than to say if it doesn't make you comfortable than don't do it. I doubt in today's financial climate they'll be equipping ramp checkers with the tools to test and verify the parameters, but I guess you never know. There are many people using such equipment today though, and the AC makes some awesome points. Some of the biggest things are single-entry-point code entry and things like that. So those things would be more worrysome because if you aren't squawking properly, then THAT is something that may be noticed.
Tim
system.
Bruce
WWW.Glasair.org
Tim Olson
PostPosted: Tue Jul 05, 2011 7:47 am    Post subject: ADS-B Transceiver... Reply with quote
I think it's best for Experimental aviations future to install the stuff, do it to certified standards so it's done right and works properly/perfectly, and to NOT spend your time drawing attention by asking them (das fed) the questions in the first place. As we all know, there are too many who don't understand experimentals, and beyond that, different FSDO's interpret things differently. Many many questions can have a variety of answers. So long as that's the case, sometimes we're better off just doing things right and not inviting regulation by asking for clarification that could never be achieved without drafting newer, deeper reaching, regulation. It's tough enough as it is. ADS-B in isn't rocket science and it's not complicated to get a working system that will give you good traffic info and report your precise location exactly. Just read that AC and make sure you work to that level of accuracy and operability.
Tim
On Jul 5, 2011, at 10:21 AM, Kelly McMullen <kellym(at)aviating.com> wrote:
Another example of the FAA left hand not having a clue what the right hand is doing. Your transponder and GPS are TSO. That means the position information complies with the requirements. Your air data system has to meet a different regulation, and I assume it does if it passes an IFR static system check.
Too many FAA inspectors have no experience/training on experimental aircraft side of the house, and rather than linking you up with someone who does, try to bluff their way into making the problem go away.
Just read an idiot article today on the "new" air traffic system that once again says ADSB/Next Gen will replace radar. If that were true, we wouldn't be required to have either Mode A/C transponders or Mode S in addition to UAT. The FAA wouldn't have gone to the totally stupid dual frequency system. Also article said lots about airlines not wanting to spend the money, without one mention of GA and who pays for that. Grump, grump.
Maybe Das Fed (if he isn't too busy stomping out office brushfires) can shine some light on the subject for us and send something off to the author of the AC to remind them they need to deal with experimental installs as well if they want the air traffic system to retain integrity. Not that I want more fed involvement, but really is necessary on something that affects all aircraft.
> system.
> Bruce
> WWW.Glasair.org
dmaib(at)mac.com
PostPosted: Tue Jul 05, 2011 8:03 am    Post subject: ADS-B Transceiver... Reply with quote
Wise words from Tim, IMHO
David Maib
40559
Flying
Tim
> aircraft.
>> RMI
>> system.
>> position data
>> what the
>> in place
>> Bruce
>> WWW.Glasair.org
